1.8 Tdci Alternator Change
STEADS
Well my battery turned up this afternoon gets my car started woopee oh no it starts to smoke like a hilly goat and fries my alternator so looks as if it was an alternator prob all along .
So my question is has any changed one and how easy is it looks quite tight to get the bolts out is a job I should tackle or through into my mates garage all help appreciated
Not to complicated, basically turn auxbelt tensioner clockwise to remove belt, disconnect alternator connections, then from underneath unbolt aircon pump if you have one, undo 3 pulley bracket bolts, loosen 3 coupler bolts, undo the 2 alternator fixing bolts, remove alternator,
Thanks Ian take it you do the whole job from underneath as I looked before and couldn't see access to bolts to remove alternator
