Speedometer And The Mot
L666JER
 Share
Quick question, does the speedo need to work for the MOT?
Picked up another zetec s yesterday and the speedo is not working, done a google search and getting conflicting answers.
Cheers, James
Link to comment
Try calling them. They'll answer that question for you. You can also check here - https://www.gov.uk/topic/mot/manuals . As far as I know, in 2012, working speedo was a requirement. It's quite easy to miss on the MOT though.
The manuals say:
Speedometer incomplete, clearly inoperative or
the dial glass broken or missing.
  • Like 1
Link to comment
Ah right, I'll give them a call before i take it in. Just don't want to be fixing things that potentially don't need doing until I know the car is sound.
Link to comment
Clearly inoperative is the key word, for mot purposes there is no roadtest so no way of knowing wether speedo works or not
Link to comment
from what I was told last year , it does not need to work
Link to comment
Yeah I did wonder how they would go about testing it. Obviously I will fix it before it goes on the road, just don't want to be in a rush to do it that's all. I'll see what they say
Link to comment
While he's testing the brakes he can see that the speedo is not working. Unlikely, but possible :)
  • Like 1
Link to comment
Not likely, the brake rollers dont go fast enough to register speedo
Link to comment
Anyone know of any common issues with it. If it's an easy fix I'll look into it now.
Link to comment
I did have a car, years ago, where the speedo wasn't working, and it did get through the MoT, although it probably shouldn't have. If you were paying attention, you probably could see that when it was on the brake rollers, but that probably depends on how conscientious the inspector feels on the day.
In my case, it was the drive cable that would have needed replacing, but would have been a real pain. Don't know whether that's a likely cause on yours.
Link to comment
The mk5 fiesta's don't have a cable as they're electronic. Makes it more complicated!
It could be the speed sensor in the gearbox :)
I'll have a look at that, gearbox is coming out anyway as the clutch has gone
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
