Revster Posted January 22, 2016 Share Posted January 22, 2016 Hi I had to jump my Ford Focus 09 plate off the other morning because the instrument light had been on all night from when I double locked the car door I think this is called cluster panel unit light the speedo and rev counter all work fine when engine is running no problems there but what I have found is the car radio is not working this has sat nav and bluetooth built in factory fitted I have had to take out a fuse 107 from the fuse box under the glove box to stop the battery from going flat because it's draining the battery all of the time... Now I have taken the radio out and checked the fuse in the back also checked all of the wiring it's all fine plus had test done to see if power is going to radio and there is but my biggest concern is this cluster unit fuse or panel has this gone or have I done something wrong when I jumped the car off and fried something can anyone help please Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 25, 2016 Share Posted January 25, 2016 if your radio fuse had gone, all interior lights should have gone. in which case, its not the fuseboard. These radio's have a fuse at the back of the stereo independant of the main fuse board. 1 Quote Link to comment Share on other sites More sharing options...
Revster Posted January 27, 2016 Author Share Posted January 27, 2016 Thank you for the reply yes the fuse has been tested its fine also there is power going to the radio but screen still blank apart from that my dash board light is staying on and draining the battery over night so hence the car had to be jumped off I was advised to pull the fuse 107 to stop the battery getting drained also today had a diagnostic check and the readings wasn't good possible stalk fault or could be the ecu or the cluster panel Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 27, 2016 Share Posted January 27, 2016 if the radio isnt turning on, and the instrument cluster light remains on, this sounds like a canbus issue to me. The radio and instrument cluster communicate on the CAN BUS, I replaced the inlaws radio with an aftermarket, and it caused the light to stay on much longer than before, reverted to the original stereo and now its back to normal. If the two cannot communicate, it tends to cause this error. Quote Link to comment Share on other sites More sharing options...
Revster Posted January 27, 2016 Author Share Posted January 27, 2016 Ok thank you for that info and will take a look cheers for your time Quote Link to comment Share on other sites More sharing options...
Revster Posted January 27, 2016 Author Share Posted January 27, 2016 Just let you know I have removed my radio and put the fuse back and the dash board light is going out now after about 20 mins so prob something to do with the radio Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 28, 2016 Share Posted January 28, 2016 Perhaps its a faulty unit then! Quote Link to comment Share on other sites More sharing options...
David K Posted April 11, 2016 Share Posted April 11, 2016 Have had a similar problem. Radio/Satnav stops working all of a sudden, then central console light will not turn off and a day or so later if car not used, battery is flat! Happened a few times and I jump started. To garage, which said it must be the Power Control Module and replaced (£600+). Same problem a day or so later! Must be a faulty PCM they said and replaced again. OK at first but now 2/3 weeks later, same problem occurring. Driving me mad! Anyone any ideas please? Quote Link to comment Share on other sites More sharing options...
iantt Posted April 11, 2016 Share Posted April 11, 2016 unplug the radio for a few days and see if evrything switches off ok and battery stays charged Quote Link to comment Share on other sites More sharing options...
David K Posted April 11, 2016 Share Posted April 11, 2016 thanks Ian - seems like a plan. Had wondered if the radio might be the problem. I assume the best thing is to take out the fuse (108)? Quote Link to comment Share on other sites More sharing options...
