fusion66 Posted January 23, 2016 Share Posted January 23, 2016 I am looking for the values/angles and tolerances of camber, caster and tracking. Whilst the camber angle is not adjustable due to the way the bottom of the strut is fixed (unlike the Fiestas) I wish to check it following a nudge by the nearside front wheel on a stone recently. My local repairer says the camber angle is 1/2 deg out but not said whether it is a positive or negative error. I am very familiar with the Fusion front end having replaced the suspension on both sides and doing the two Ford mods at the same time and think I should check and confirm, or otherwise, the stated error. Thanks in advance. David G (F66) Quote Link to comment Share on other sites More sharing options...
iantt Posted January 23, 2016 Share Posted January 23, 2016 Do you want figures in decimal degrees or degrees and minutes? Quote Link to comment Share on other sites More sharing options...
fusion66 Posted January 24, 2016 Author Share Posted January 24, 2016 Thanks Ian. Decimal degrees will be fine. Ta muchly. Regards, David G (F66) Quote Link to comment Share on other sites More sharing options...
iantt Posted January 24, 2016 Share Posted January 24, 2016 Caster +3.72 degrees, tolerence +4.72 to +2.72 Camber -1.05 degrees, tolerence +0.20 to -2.30 tracking toe in 0.50 degrees +/- 0.34 ( 3.3mm toe in +/- 2.3mm) Quote Link to comment Share on other sites More sharing options...
fusion66 Posted January 25, 2016 Author Share Posted January 25, 2016 Ian ... Many thanks...much appreciated. David G (F66) Quote Link to comment Share on other sites More sharing options...
JoJo2222 Posted January 25, 2016 Share Posted January 25, 2016 May I ask what the 2 ford mods are please ? Quote Link to comment Share on other sites More sharing options...
fusion66 Posted January 27, 2016 Author Share Posted January 27, 2016 These are 2 zinc rings and 2 rubber rings which fit below the front coil springs. The idea is to reduce spring failures. Check the online parts catalogue at eucatparts.com There is a mod sheet there. Parts can be had direct from Ford. I suggest you see my earlier postings on this subject. Hope this helps! Regards, David G (F66) Quote Link to comment Share on other sites More sharing options...
