Vinchenzo7
Mk3 2013 radio code required?
17 hours ago, alexp999 said:
Nope, it doesn't have one.
That's not strictly true. The radio does have a code but it's linked to the car's VIN. The system checks that the two match before allowing operation. This means you don't have to re-enter the code if the battery is disconnected.
I'm only repeating what is printed in the handbook for my 2012 Mk3.
Would it be the same on the mk2s and 2.5s ?
Or do they still need a Code?
They need a code.
17 minutes ago, alexp999 said:
If that was the case you wouldn't be able to swap headunits but you can. Fiesta is the same.
I have an aftermarket unit fitted professionally, when it was fitted, there was no mention of codes. So it should be alright for me to change battery?
12 minutes ago, alexp999 said:
If you have an aftermarket unit then it depends on the unit. I'd check the manual for it before unplugging the battery
No manual :( it's a android unit from China.
Might just have to see what happens :S
If it was fitted professionally it might have been coded to the car.
Hmm hopefully, might give them a call to check.
