Fiesta Bluetooth lockup and reset
#1
Posted 04 October 2009 - 01:31 PM
We had a bit of a problem with our new Fiesta (mk 7) when the bluetooth locked up a few days ago. All other audio features etc were fine but try as we might just couldn't get any phone to talk to the car. Managed to get it working again (on Ford technical's advice) by dis/re-connecting the battery. After that all was fine again.
The problem coincided with using a TomTom One sat nav linked to a Sony Ericsson C902 via bluetooth for traffic and "safety camera" updates in the car for the first time.
Haven't tried the setup since and the car's bluetooth has been absolutely fine!
Anyone else encountered similar?
Cheers
Mark
#2
Posted 04 October 2009 - 04:50 PM
It works fine on the whole but is by no means glitch free.
#3
Posted 01 February 2010 - 09:02 PM
I've got exactly the same problem as this, and its taken down my USB port as well by the looks of it, so task for tomorrow is to disconnect / reconnect the battery!We had a bit of a problem with our new Fiesta (mk 7) when the bluetooth locked up a few days ago. All other audio features etc were fine but try as we might just couldn't get any phone to talk to the car. Managed to get it working again (on Ford technical's advice) by dis/re-connecting the battery. After that all was fine again.
Now this maybe a silly question, but is there anything I need to watchout for when doing this - Radio codes, alarms, immobilisers (yes, thats probably spelt wrong) etc?
#4
Posted 02 February 2010 - 12:40 AM
Exactly the same thing happened to me on the day of the FOC meet on the 17th! (Maybe I mentioned it at the time, I can't remember). It fixed itself up fine in the end. Although your plan with the battery is probably quicker so I wont bother going into details. GL ALL!!!
#5
Posted 02 February 2010 - 09:44 AM
You did mention it....although I had completely forgotten that - how long did it take to sort itself out?Exactly the same thing happened to me on the day of the FOC meet on the 17th! (Maybe I mentioned it at the time, I can't remember). It fixed itself up fine in the end. Although your plan with the battery is probably quicker so I wont bother going into details. GL ALL!!!
#6
Posted 02 February 2010 - 12:14 PM
About three days of half baked attempts. Then after about 4 days it wasn't working still. What I did was manually hook the car up to the phone and the phone up to the car, some time is dropped the connection after about 1 minute. In the end it stayed connected though and has been fine since. Have you tried going into your phones settings, doing a scan, then pairing with the car manually, and vise versa with the car?
#7
Posted 02 February 2010 - 01:08 PM
Yeah, tried the manual bits from both sides a good 5-10 times on Sat just after it went down...with minimal sucess. Come Sunday, the phone was failing to even see the car's bluetooth at all and the USB port wouldn't read.About three days of half baked attempts. Then after about 4 days it wasn't working still. What I did was manually hook the car up to the phone and the phone up to the car, some time is dropped the connection after about 1 minute. In the end it stayed connected though and has been fine since. Have you tried going into your phones settings, doing a scan, then pairing with the car manually, and vise versa with the car?
I don't seem to be able to turn the bluetooth off in the car (it just turns straight back on) and I can't debond my phone (delete it from the list) so I'm pretty sure its the car not the phone...although time will tell.
My master plan to play with the battery has so far been scuppered by heavy rain, so might go and sit in the car and have another couple of attempts with the manual connect.
#8
Posted 02 February 2010 - 01:20 PM
#9
Posted 02 February 2010 - 05:16 PM
Fuse 21 it is then!......One thing you could try from inside the car (in the dry) is simply remove and replace the fuse. However as the head unit will be "on", there is a slight chance of the fuse blowing when you re-insert. Manual will say which fuse to pull
Edit:
Right, pulled both the "Audio System / Bluetooth" and "Audio System / Instrument cluster" fuses and TBH nothing has changed - the stereo didnt even forget any of its settings, so I'm guessing I didn't do that quite right...may have to resort to disconnecting the battery afterall.
#10
Posted 03 February 2010 - 02:29 PM
As expected, pulling off the battery negative lead seems to have done the job. To my surprise, the only settings the car seems to have forgotten are the time and date - will have to see if its lost anything else next time I drive it, but so far, so good.
#11
Posted 03 February 2010 - 02:37 PM
#12
Posted 17 February 2010 - 08:42 PM
Nope, looks like its gone again. USB is still working, but the bluetooth is doing exactly what it was before. Think I might need to take it into a Ford dealer to get them to look at it.EXCELLENT NEWS!!!
#13
Posted 17 February 2010 - 11:07 PM
#14
Posted 09 April 2010 - 06:10 AM
This is the second time I have had problems with it. The first time I switched the unit off and on while I was getting a call which caused it to start working in reverse. When I switched the car off the radio will come on but not play anything. When I switched the car on it would switch the unit off.
I think that Ford should do a firmware update to fix these kind of problems.
#15
Posted 09 April 2010 - 12:10 PM
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
