jpeck76 Posted February 8, 2016 Share Posted February 8, 2016 Hello Everyone, I’ve just joined this website and this is my first post (first on any website), so if I get anything wrong please accept my apologies in advance. So trying to keep this short…..I have a question I’m hoping someone may be able to answer regarding my MK2 Focus. It’s a 2006 1.6 Petrol model with the bog standard 100ps engine (not the VVT one), which I believe is a Zetec-SE or Sigma, even though it’s badged as a Duratec. The car has just done 95K, so is due a new Timing Belt at some point soon. Normally I would do these type of jobs myself (changed many a Fiesta/Escort etc in the past) but having done a bit of research it appears things aren’t the same with these newer engines and the job now involves special tools, re-timing of Camshaft pulleys and non-keyed Crank pulleys, all of which has put me off a bit. I’ve been quoted 300-500 pounds for the pleasure (Cam Belt/Tensioner/Water Pump/Aux Belt) by a few local garages, so I’ve been thinking I may wait until the Summer with the better weather and do the job my self. My concerns are that should the Cam Belt or Tensioner fail then its game over, however I’ve found quite a bit of conflicting information on the web as to weather this engine is an Interference or Non-Interference (Free-Wheeling) model. Is there anyone out there (maybe a Ford Tech), who could give a definitive answer as weather my Pistons and Valves are going to get intimate should the worst happen? Any info on the above or any pointers/tips regarding changing the belt would be much appreciated Thanks in advance All the best John Quote Link to comment Share on other sites More sharing options...
iantt Posted February 8, 2016 Share Posted February 8, 2016 Belt or tensioner failing will definitely have pistons bending the valves, As for changing it , you need to factor in the cost of special tools with the cambelt kit, auxullary belt kit, water pump 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted February 9, 2016 Share Posted February 9, 2016 I tackled this job myself recently with advice from iantt (above). Parts using Halfords trade cost me around £100. Tools cost me a total of £60. Took me 3 days on and off due to incorrect tools sent by suppliers :( www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
cmozzer Posted February 14, 2016 Share Posted February 14, 2016 just had my belt and pulleys done at a cost of £250 all in . mines a 1.6 petrol lx , apparently water pump aint driven by belt so if it aint leaking leave alone , might save you a few quid . Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted February 14, 2016 Share Posted February 14, 2016 just had my belt and pulleys done at a cost of £250 all in . mines a 1.6 petrol lx , apparently water pump aint driven by belt so if it aint leaking leave alone , might save you a few quid . What engine do you have?... Duratec? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
jpeck76 Posted February 14, 2016 Author Share Posted February 14, 2016 Thanks for the info guys, I think I'll let the local garage do it for piece of mind, 300 pounds for everything is probably the going rate, it's certainly much cheaper than a new engine if something does fail and to be honest I don't fancy laying on the driveway with a set of axle stands. Getting a bit too old (lazy) for these things.... 1 Quote Link to comment Share on other sites More sharing options...
Bullring Autocentre Posted February 20, 2016 Share Posted February 20, 2016 We can offer to replace that timing belt for £250 incl VAT. Get in touch via our website Quote Link to comment Share on other sites More sharing options...
