Sign in to follow this
James Atkin
Engine Management Light
Hi All,
I have a Ford Ka 1.3 2003 which was starting to run a bit roapy when it got warm - occasionally missing.
I have just replaced the leads and plugs and it now sounds lovely - problem is, the Engine Management light came on after these were replaced!
How can I reset it? I bought a USB VAG-COM type interface some time back for an older car and it appears to be the same connector. I have researched around on the web and it looks like there are at least 3 different communications standards for that style connector!
Any idea if I can use this to diagnose the fault / reset it? I was given an old version of VAG-COM some time back, but it only appears to deal with VW/Skoda/Audi/Seat.
Any thoughts would be appreciated!
Thanks,
James
That is an interesting thought...
btw, I have tried disconnecting the battery for over 1 hour - no luck :-(
Interestingly enough, the change of the leads/plugs has certainly fixed the problem - drives lovely now!
There are rumors that it is possible to reset the ECU using the ignition key??? This really does seem far to useful to be true ;-)
