Update Sync 2 The Easy Way
alexp999
 Share
Can I please have the link for the 3.10 EU version? I now can use the language packs links and update to my language pack. That was what was holding me of.
Thank you bannko and vincentka for the share :yahoo:
Link to comment
HERE
Who want DONATE ME via paypal vincentka76 (at) yahoo.com
  • Like 1
Link to comment
Thank you very much!
Update: I installed the update today. took around 40/45 minutes. All went well, and the system is working fine. Didn't noticed any difference, but all is working.
Thank you guys.
Link to comment
Hi I am picking up a 16 plate titanium focus running sync 2 navigation and live in the UK. I have downloaded the Gen2v310build16180_Update_package_EU_Language_pack is this all I need to save on the fat32 memory stick for it to update with English settings?
Link to comment
Similar to Leprekorn, I'm in the UK and picked up my 2016 Focus Titanium X with Nav yesterday, and I'm wondering about the file to use. Earlier in the thread, someone said to use Language pack 5 (presumably because English (British) is listed first? - just guessing) but the file Gen2v310build16180_Update_package_EU_Language_pack.zip contains both EA5T-14F497-CF (EU Language pack 2) and EA5T-14F497-GF (EU Language pack 6), although the autoinstall.lst only mentions at item7 EA5T-14F497-CF. Therefore as I understand it, pack 6 in the file above would never be used.
So, if I use this file with the included pack 2, would my system default to the first language in the pack 'German' and I'd have to change it to English (British) -or- should I remove packs 2 and 6 then add pack 5 from EA5T-14F497-FF_64707.ZIP renamed to EA5T-14F497-FF.ZIP and modify autoinstall.lst item7 as follows:-
Item7 = EA5T-14F497-FF
Open7 = SyncMyRide\EA5T-14F497-FF.ZIP
Or perhaps I shouldn't mess with it at all since I've only just got it  :smile:
Link to comment
hi guys, couple of question..
Do you have, maybe, also EU Language pack 3?
And second question is.. Is there any issues to update from 3.8 to 3.10?
edit : found it :) thanks anyway !
Link to comment
Sent you ready to install package for LANG PACK 3.
  • Like 1
Link to comment
thanks mate :)
Link to comment
thanks vincentka , license its ok :):) :] Thank U
  • Like 1
Link to comment
Hello.
I have my Ford Focus of November 2014 Titanium with 8" screen buy in France.
I already have navigation enabled. Do I need a key activation to update my Sync 2?
What should I do to upgrade to version 3.10?
Thank you in advance for your response :-)
Link to comment
16 minutes ago, zetiti said:
Hello.
You just need to download the update and install it. That is all. For installation steps see first page of this thread.
  • Like 1
Link to comment
As simple as that, I would have thought it was more complicated. I will thank you for your answer :-)
  • Like 1
Link to comment
Bannko
Going to pluck up courage and install the update on my car today, looking a the first page posts it mentions that they should be three files on the usb stick, I have only two (see my previous post),is this ok ?.
Also will the update be in English or will I have to change it after the installation.
Thanks in anticipation
Link to comment
You've probably got the "do not index" file missing, it will still work fine.
The important bits are autoinstall.lst and a syncmyride folder.
  • Like 1
Link to comment
As Alex said, you are good to go :) on usb should be only SyncMyRide folder and autoinstall.lst.
English will stay, no addiitional settings after the update. But the NAV settings and phone will be lost...u have to set it up again.
Link to comment
Does that mean I will have to delete the main folder on the pen drive (GEN2V310BUILD16180updatepackageEULangpack2) ,the other two are sub folders when the main one is opened or will Sync 2 auto recognise them.
Link to comment
You need to have the 2 files in the root of your drive.
Sent from my SM-G930F
Link to comment
sync will not recognize them if they are in folder. in general SyncMyRide folder and autoinstall.lst must be in USB's root.
  • Like 1
Link to comment
Perfect ;)
  • Like 1
Link to comment
Thank you all for your answers, I now have two files on my pendrive
1) SyncMyRide
2) autoinstall.lst
I will go ahead and install the updates tomorrow.
Many Thanks
  • Like 1
Link to comment
Remember to remove any other usb sticks before starting the update or it won't run.
Link to comment
Thanks Stoney
If I can just explain what I have done (I had to borrow a windows computer) I downloaded the file Bannko sent me, then extracted it into another folder, I opened the main extracted file and copied the two sub files (SyncMyRide & autoinstall) onto a pendrive, is this the correct way.
  • Like 1
Link to comment
Correct, now just plug and play :) note that ur engine must be running the whole time, start/stop set to off.
  • Like 1
Link to comment
Many Thanks
I have just updated my system in just under 30 minutes , bit of a scare at first, it would not recognise my first pen drive I used so I downloaded the files onto another drive and that worked OK.
As you mentioned I have lost my satnav and phone settings but wireless settings untouched, do you suggest I do a master reset ?.
Thank you all for your help.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
