Colin1969 Posted February 12, 2016 Share Posted February 12, 2016 I have a new ecoboost 125 titanium x , just wondering is there any way to make the central locking lock automatically after driving off , reason is incase i forget to do it manually , people now days just try to hijack the car to steal from you . My older 2008 BMW does it and so does my wife Clio do it too. Any advice thanks Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted February 12, 2016 Share Posted February 12, 2016 You can enable it via focccus software using OBD cable, but you might be able to do it by messing in the settings menu on your radio display. Quote Link to comment Share on other sites More sharing options...
JSMarsden Posted February 12, 2016 Share Posted February 12, 2016 I never liked this feature just incase I was involved in an accident and was unable to unlock the doors (knocked out/trapped or whatever?) it would make it a bit harder to get me out of the car if I was trapped (a very big likelihood and far fetched) but could happen! If I feel I'm in a bit of a rough area i'll just lock them with the button! 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted February 12, 2016 Share Posted February 12, 2016 10 minutes ago, JSMarsden said: I never liked this feature just incase I was involved in an accident and was unable to unlock the doors (knocked out/trapped or whatever?) it would make it a bit harder to get me out of the car if I was trapped (a very big likelihood and far fetched) but could happen! If I feel I'm in a bit of a rough area i'll just lock them with the button! This will be why Ford don't enable it by default and have blocked it from being turned on with IDS. 1 Quote Link to comment Share on other sites More sharing options...
Willy Posted February 13, 2016 Share Posted February 13, 2016 It can't be turned on in the Fiesta as Alex says. Sent from my SM-T800 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Omer Kara Posted February 13, 2016 Share Posted February 13, 2016 So, as soon as we press the lock button from inside, we're in danger of trapped in the car. If that's the case, the lock button should not be in there. This should not be the excuse to disable auto lock feature. If the car can explode airbags in split second, it can easily unlock the doors at the same time. Dumb excuse i think and this feature is enabled in USA by the way. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted February 13, 2016 Share Posted February 13, 2016 The car will attempt to auto unlock the doors but depending on the location and severity of impact I think they found it could be unreliable hence disabling the auto locking feature as a safety precaution. By using the manual lock you make your own judgement call. I wouldn't want to be without it driving through or parking in certain places. At least you can unlock it again when you want to. 1 Quote Link to comment Share on other sites More sharing options...
MarksST Posted February 14, 2016 Share Posted February 14, 2016 As Alex said, if the doors auto locked and trapped you in the car you could try and sue Ford as its a feature they enabled, if you lock the door yourself then that's down to you. just get into the habit of pressing the lock button when you get i, it will become second nature, it also defeats the thieves/hi jackets who don't prefer the car to be over 5mph before attempting to get in. strangly my 15 plate transit has auto locking 1 Quote Link to comment Share on other sites More sharing options...
Omer Kara Posted February 14, 2016 Share Posted February 14, 2016 6 hours ago, MarksST said: As Alex said, if the doors auto locked and trapped you in the car you could try and sue Ford as its a feature they enabled, if you lock the door yourself then that's down to you. just get into the habit of pressing the lock button when you get i, it will become second nature, it also defeats the thieves/hi jackets who don't prefer the car to be over 5mph before attempting to get in. strangly my 15 plate transit has auto locking Same fiesta in usa has auto locking too. Quote Link to comment Share on other sites More sharing options...
MarksST Posted February 14, 2016 Share Posted February 14, 2016 Well they've done it for some reason so your choices are; Get on to ford HQ and get them to enable it. Import a US car Or shut the door and press the button on the dash Quote Link to comment Share on other sites More sharing options...
Tomppa Posted February 6, 2020 Share Posted February 6, 2020 If you lock the doors, central locking will be opened when airbag module detects the accident, IOW goes to crash mode, also shuts the fuel pump etc... Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted February 8, 2020 Share Posted February 8, 2020 On 2/13/2016 at 2:27 AM, Willy said: It can't be turned on in the Fiesta as Alex says. Sent from my SM-T800 using Tapatalk You need ELM 327 modified cable Forscan software Swich on in BCM (and IPC if you want to be able to toggle it on and off) Quote Link to comment Share on other sites More sharing options...
Willy Posted February 8, 2020 Share Posted February 8, 2020 6 hours ago, DaveT70 said: You need ELM 327 modified cable Forscan software Swich on in BCM (and IPC if you want to be able to toggle it on and off) Or this way Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted February 8, 2020 Share Posted February 8, 2020 Not for UK models Quote Link to comment Share on other sites More sharing options...
vix p Posted August 11, 2020 Share Posted August 11, 2020 Yes i found a video on YouTube. You start the engine press the unlock button 3 times ont the door. Then engine off press the unlock button 3 times again start the engine. You only have 30 seconds to do the process. Hope this helps Quote Link to comment Share on other sites More sharing options...
runamonk Posted August 12, 2020 Share Posted August 12, 2020 I used forscan to enable it in the control module, then went through the above procedure to engage it. Hit 15mph and the doors automatically lock. Quote Link to comment Share on other sites More sharing options...
Treef Posted August 14, 2020 Share Posted August 14, 2020 On my Mk7 you can program the key to only open the drivers door on 1 click or all doors on 2 clicks https://www.fordownersclub.com/forums/topic/22360-activating-single-door-unlock-and-all-door-on-your-ford/ Quote Link to comment Share on other sites More sharing options...
Bobr Posted August 14, 2020 Share Posted August 14, 2020 There is absolutely no way I would have the doors locked while I am driving. Experience of 30 years in the police tell me that this is a stupid idea. Quote Link to comment Share on other sites More sharing options...
Mavroz Posted August 14, 2020 Share Posted August 14, 2020 1 hour ago, Bobr said: There is absolutely no way I would have the doors locked while I am driving. Experience of 30 years in the police tell me that this is a stupid idea. Have to agree with you there.... Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 14, 2020 Share Posted August 14, 2020 I guess it depends where you drive and who you are. As a pale, weak, scrawny guy that regularly used to drive rough areas at night (for college and work) I felt far safer with the doors locked and it's something that's stuck ever since. Even now I still don't like having windows down during the day in town when there are lots of people about - even less so at night. There's absolutely no way I could fend off a carjacker in real life. It's not just attackers and car jackers either, if you've got a laptop on the backseat, or a puppy in the boot, anyone can get those open and run off with your dog or laptop before you've worked out what the noise was. It is of course a balance of risk...but modern door locks are designed to release in the event of a crash nowadays. Which is much safer than the manual locks I had when I first started doing it. It's also only the external locks as someone mentioned above, so pulling the internal handle still releases the door, just takes a double pull in most cases (extra half a second). And if you're not in a position to pull the handle yourself (heart attack at traffic lights maybe?) then a passer by could smash the side window and reach in to pull the handle. I'm sure there must be scenarios where it doesn't work...and would be interested to hear of any you can think of! Quote Link to comment Share on other sites More sharing options...
Bobr Posted August 14, 2020 Share Posted August 14, 2020 8 hours ago, TomsFocus said: I guess it depends where you drive and who you are. As a pale, weak, scrawny guy that regularly used to drive rough areas at night I suppose being a veteran and an ex copper and six feet two and 14 stone does make a difference.😁 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 14, 2020 Share Posted August 14, 2020 1 minute ago, Bobr said: I suppose being a veteran and an ex copper and six feet two and 14 stone does make a difference.😁 Yeah, I don't think anyone's going to be ripping you out of the driver's seat any time soon! It is interesting the different world perspectives we'll have. I'm about 6 foot, but have absolutely no muscle (weigh about 8 stone) and have never hit anyone in my life...wouldn't even know how! As a result, I'm constantly on the lookout for potential attackers in the real world. 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted August 17, 2020 Share Posted August 17, 2020 On 8/14/2020 at 8:43 AM, Bobr said: There is absolutely no way I would have the doors locked while I am driving. Experience of 30 years in the police tell me that this is a stupid idea. There is absolutely no way I would have my wife or daughter drive around without the doors locked so someone could pull the out and batter the keys off them. My experience of today's police is they wouldn't turn up for about three days, too busy pandering 2 Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted August 17, 2020 Share Posted August 17, 2020 I agree, but without the knocking the police bit. I've seen too many bag snatches and nutters trying doors in queues to ever NOT lock my doors. Quote Link to comment Share on other sites More sharing options...
brains_t Posted August 19, 2020 Share Posted August 19, 2020 Needed in some towns where crooks go for handbags etc on the passenger/back seat. Peak is evening/nights during the period of when the clocks go back and Xmas when cars are stuck in rush hour or shopping traffic. I would recommend as a minimum you do the two click needed to open all doors, that way if someone tries you passenger/back door you can hit the lock button. Quote Link to comment Share on other sites More sharing options...
