Driver side window
teaandpies
 Share
My driver side window is falling down when I close the door. The motor seems to be working but when I try to use it to put the window up nothing happens but I can hear a crunching sound.
Is this an easy fix or do I need a new motor?
Link to comment
sounds like its come adrift from the clamps,so all your hearing is the regulator going up and down.
Link to comment
Is that an easy fix?
Link to comment
door card off,gently remove plastic weather sheet if fitted?
now this is where it can be a bit complicated,BE VERY CAREFUL how you check to see if the regulator is working
because you could break the glass???if it gets snagged.space is limited in there,your see what i mean when you do it.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
