Fiesta booming noise at 45 mph
4 replies to this topic
#1 arnieboy
arnieboy
    Newbie
  • Pip
  • 4 posts
  • Ford Model: Fiesta 1.8 diesel
Posted 28 May 2008 - 12:17 PM
I borrowed my wife's 93 Fiesta 1.8 diesel which she's had from new. At about 45 mph a sort of booming resonant noise appears and goes once past 50 mph. It comes back again around 65 mph but not as loud. The noise is different to a wheel bearing and the car drives normally apart from this. The noise is difficult to pinpoint but I think it is from the front. Can anyone suggest any cause, could it be a transmission noise? If you drive locally ie 30 mph zones you wouldn't hear any noise at all. Thanks.
#2 Steve
Steve
    Administrator
  • Admin
  • 4,831 posts
  • Ford Model: Kugy
Posted 31 May 2008 - 10:23 PM
have you checked all the tyres for bulges or splits?
Also hae you had the weehls checked for buckles or out of balance?
wheels bearings would be more apparent if you gently swerve the car left to right you should hear it change sound.
After this i would then look towards towards the transmission
#3 arnieboy
arnieboy
    Newbie
  • Pip
  • 4 posts
Posted 07 June 2008 - 09:00 PM
Thanks for the advice. All tyres were changed this year at the same time and are the same as before, i.e. Michelins. I don't remember if the wheels were balanced but I don't get any vibration at all just the booming resonant noise. I had a wheel bearing go once before and it was much more high pitched so I am leaning towards a transmission noise now.
#4 Steve
Steve
    Administrator
  • Admin
  • 4,831 posts
  • Ford Model: Kugy
Posted 07 June 2008 - 10:08 PM
is the noise still apparent if you
1. press the clutch down at 45
2. coast in neutral at 45?
#5 arnieboy
arnieboy
    Newbie
  • Pip
  • 4 posts
Posted 10 June 2008 - 10:51 AM
Thanks, I'd thought of 1. and pressing the clutch makes no difference. I am guessing 45 mph is a resonant frequency spot for something vibrating. It's weird as the car drives normally other than this noise.
I'll try No.2 to see what happens.
