digger2020 Posted March 8, 2016 Share Posted March 8, 2016 Hi all. Hope someone can advise me....it's been a while since I've visited the site as not been driving for some time! Problem I have on my 57 plate 2.0tdci Mondeo tit x is the indicators do not flash when locking but do when unlocking. Have tried one and two presses of the fob. All doors lock and unlock correctly including deadlocking and convers dash shows alarm activation. Boot and bonnet switches appear to be working as they should also. Should I be looking to replace the c/l ecu in the osr quarter behind the boot lining or is there another possibility that anyone may have come across please? Grateful for any input! Cheers guys. 馃憤 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 14, 2016 Share Posted March 14, 2016 do all doors really lock? it could be that a fuse has gone for one of the door locks? Quote Link to comment Share on other sites More sharing options...
Dan62 Posted March 15, 2016 Share Posted March 15, 2016 I would suspect the the tailgate anti-theft inhibit switch. The tailgate usually has 2 switches, 1 for the courtesy lamp and another for the alarm inhibit. Depending on the model they can be internal to the motor asm or 1 of them external. Remove the trim panel and see if you can see it, the anti theft switch would be the external one if its not within the motor asm. Quote Link to comment Share on other sites More sharing options...
digger2020 Posted March 15, 2016 Author Share Posted March 15, 2016 22 hours ago, jeebowhite said: do all doors really lock? it could be that a fuse has gone for one of the door locks? Yes all lock and deadlock. Can't be opened from inside or out. All fuses ok. Quote Link to comment Share on other sites More sharing options...
digger2020 Posted March 15, 2016 Author Share Posted March 15, 2016 11 hours ago, Dan62 said: I would suspect the the tailgate anti-theft inhibit switch. The tailgate usually has 2 switches, 1 for the courtesy lamp and another for the alarm inhibit. Depending on the model they can be internal to the motor asm or 1 of them external. Remove the trim panel and see if you can see it, the anti theft switch would be the external one if its not within the motor asm. Thanks very much for that suggestion. I'll take a look at the tailgate electrical bits. Is there a way to bypass the offending item if it is indeed the problem? Thanks once again for posting 馃憤 Quote Link to comment Share on other sites More sharing options...
