Montigoo Posted March 31, 2016 Share Posted March 31, 2016 So I eagerly connected my phone to the Ford Sync system when I got my Ford Fiesta Eco-Boost last January.. Connected swimmingly - absolutely flawless performance for both audio and media from then until about two days ago when it booted my phone off as a paired 'pal' Tried to reconnect 2,346 times since then but failing every time.. :( I get the "waiting for phone conformation" message before an agonising wait to then get a "pairing failed" message even though i have accepted the pin code it sends over on both my phone and the car.. That actually only goes to further confuse me, because I do get the pin code that the Sync system sends over to my phone.. So they must "see" each other..? I've done at least 3 Master Resets on Sync, I've turned my phone off / on and I've done an unpaired / attempted repair more times that I can remember but nothing..!? Can a Ford Brother (or sister) help me out.. I live for the ability to voice command my car to call my local Chinese on a Friday.. And sadly that privilege has been taken from me.. :-/ Cheers in advance Montigoo Quote Link to comment Share on other sites More sharing options...
JSMarsden Posted March 31, 2016 Share Posted March 31, 2016 I had recent issues, when my Samsung when it to be fixed I got my old iPhone back out and everytime I got the sat nav on my phone telling me something it 'called' my car to tell me. However now on my Samsung had a few issues connecting today as it wasn't picking up messages (I clicked deny by accident on my phone, but then proceeded to turn the settings back on in the phone to accept messages, but sync still wasn't having any). I had to go into my phone and make it 'forget' the SYNC device, and then partner it up again. Once I followed the normal process of adding it via sync first, then finding sync on my phone it seemed to work fine again :/. Have you updated your phone since/what phone is it? Quote Link to comment Share on other sites More sharing options...
Maxxxykins Posted March 31, 2016 Share Posted March 31, 2016 11 hours ago, Montigoo said: So I eagerly connected my phone to the Ford Sync system when I got my Ford Fiesta Eco-Boost last January.. Connected swimmingly - absolutely flawless performance for both audio and media from then until about two days ago when it booted my phone off as a paired 'pal' Tried to reconnect 2,346 times since then but failing every time.. :( I get the "waiting for phone conformation" message before an agonising wait to then get a "pairing failed" message even though i have accepted the pin code it sends over on both my phone and the car.. That actually only goes to further confuse me, because I do get the pin code that the Sync system sends over to my phone.. So they must "see" each other..? I've done at least 3 Master Resets on Sync, I've turned my phone off / on and I've done an unpaired / attempted repair more times that I can remember but nothing..!? Can a Ford Brother (or sister) help me out.. I live for the ability to voice command my car to call my local Chinese on a Friday.. And sadly that privilege has been taken from me.. :-/ Cheers in advance Montigoo Have you tried to disconnect the bluetooth module physically/completely? Quote Link to comment Share on other sites More sharing options...
Montigoo Posted March 31, 2016 Author Share Posted March 31, 2016 Cheers for the replies.. Funnily enough my Samsung today pushed me for an software update which Ive now done so I will see if that has impact tonight.. Maxxxykins - how do you mean? Remove it physically from the car? All I've deleted the connections between the car and my phone numerous times and tried to then repair them if that's what you mean? Cheers Montigoo Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ams Posted March 31, 2016 Share Posted March 31, 2016 Hi Montigoo, I had pretty much same problem with my last fiesta Zetec. As Maxxxykins said, try and reset bluetooth module. You don't have to remove it, just look for Fuse in passenger compartment for audio system. Remove it and wait at least 60 seconds before plugging it back in. Hopefully this will fix your issue. Cheers Ams 1 Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted March 31, 2016 Share Posted March 31, 2016 I've had the same issue on my ST and finally sorted it by doing a hard reset of my phone. All you do is hold the power button and the home button down at the same time till the phone turns off. Then wait for it to reboot it's self the I repaired it with sync and it connected and has worked ever since. It's worth a try before you start removing fuses to reset the bluetooth module. Quote Link to comment Share on other sites More sharing options...
CookieM Posted March 31, 2016 Share Posted March 31, 2016 There's an option to do a sync reset in the menu somewhere. Remove all the device from the car, unpair sync on your phone, do the reset from the menu and try pairing again Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Montigoo Posted April 5, 2016 Author Share Posted April 5, 2016 On 31/03/2016 at 2:43 PM, Ams said: Hi Montigoo, I had pretty much same problem with my last fiesta Zetec. As Maxxxykins said, try and reset bluetooth module. You don't have to remove it, just look for Fuse in passenger compartment for audio system. Remove it and wait at least 60 seconds before plugging it back in. Hopefully this will fix your issue. Cheers Ams Ams! Yes! After 3 weeks of non connectivity my SYNC is officially back working again! Would like to say cheers to all the replies and advice - I pretty much tried all the solutions suggested fixes including a full phone factory reset (joy) but the only thing that's worked was locating the fuse for the SYNC / bluetooth and doing a quick yank out and back in. After that It worked effortlessly. I just really hope now that it was the correct fuse I took out and not the one for the air bags or that.. If you see something on the news about my car blowing up mid-drive at least you'll have peace of mind my SYNC was working fine.. :) Cheers again, Montigoo 1 Quote Link to comment Share on other sites More sharing options...
Ams Posted April 6, 2016 Share Posted April 6, 2016 Glad to know it all worked out for you. Enjoy 1 Quote Link to comment Share on other sites More sharing options...
