kw98 Posted April 5, 2016 Share Posted April 5, 2016 Hello, I'm currently a learner driver with my own car, it was going so well up until a month after paying it all off, its a 2003 ford fiesta finesse 1.3, mileage at about 60,000 I'm having a problem with that once i get moving itll be all fine and then for no reason, i lose power, revs and no matter if my foots to the floor it wont accelerate, when this happens i normally put the car into neutral and give it full revs to idle 2/3 times then it the car is perfectly fine, it has got a check engine light on the dash but that was from the lamda sensor which has been replaced, ive seen it could be a clogged MAF sensor but i dont want to tinker with it if its not, need some help Quote Link to comment Share on other sites More sharing options...
terry-1987 Posted April 5, 2016 Share Posted April 5, 2016 Get it hooked up to a Diagnostic scanner that will put you're engine light off with that part being replaced already and tell you any new faults Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 5, 2016 Share Posted April 5, 2016 You don't have a MAF so its not that ! Get the codes read and reset, a code reader or USB/Bluetooth OBD device is a good cheap investment if you want to do it yourself. Quote Link to comment Share on other sites More sharing options...
