jimmy46 Posted April 13, 2016 Share Posted April 13, 2016 Hi guys has anyone changed their standard headlights for projector type is it easy and where to get em thanks jimmy Quote Link to comment Share on other sites More sharing options...
alexp999 Posted April 13, 2016 Share Posted April 13, 2016 It won't be easy doing official Ford ones, you need levelers, ballast, headlamp washers. The latter means different screenwash bottle, bumper, pump, pipes, etc. And then it all needs turning on with IDS. If I wanted projectors, I'd go for something like this instead: http://www.european-parts.net/product_info.php?info=p1645_led-headlights-focus-mk3-black.html Quote Link to comment Share on other sites More sharing options...
kpg Posted April 13, 2016 Share Posted April 13, 2016 It won't be easy doing official Ford ones, you need levelers, ballast, headlamp washers. The latter means different screenwash bottle, bumper, pump, pipes, etc. And then it all needs turning on with IDS. If I wanted projectors, I'd go for something like this instead: http://www.european-parts.net/product_info.php?info=p1645_led-headlights-focus-mk3-black.html You might need to double check but I think these are LHD. I've Ben looking for RHD ones for aaaaages, just doesn't seem to be any at all :-/ ? Sent from the pub with a pint in the other hand. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted April 13, 2016 Share Posted April 13, 2016 Might be worth messaging them to see if they can be configured for both LHD and RHD. Being projector there might just be a lever to set them. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 13, 2016 Share Posted April 13, 2016 The lever on both original and aftermarket projector headlights is only to temporarily convert the lights from LHD to LHD or vice versa. This will only prevent the lights from blinding other traffic and does not fully convert the light beam. The lever is not a permanent solution. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted April 13, 2016 Share Posted April 13, 2016 I thought maybe the aftermarket ones might be setup to be positioned for either left or right. 1 Quote Link to comment Share on other sites More sharing options...
