kevb2016 Posted April 17, 2016 Share Posted April 17, 2016 We have recently purchased a 56 plate focus tdci. The dealer has just been fobbing us off so have taken the car to an independent garage for them to try to figure out what is happening... The car itself starts and drives perfect until you reach 181 miles of driving (during the week) then it will jump and keep jumping until you lock the car and sit it out for 5 minutes (sometimes this won't work and it will be like it the rest the day but then fine the following day) now once in this mode it will lose power-but won't stall - will suddenly regain power. We have so far changed the fuel filter. It's been hooked to diagnostics while driving and was reading temperature of -56 ' c. ... any recommendations?? Quote Link to comment Share on other sites More sharing options...
BOF Posted April 17, 2016 Share Posted April 17, 2016 Assuming this isn't a dealer's problem (which it usually would be if you bought it from the trade)... When you say '-56C' what do you mean; oil temp water temp or air temp? In any case that's probably a sign that a sensor is not being read. The sensor itself has failed the wiring has failed or the module reading it has failed. The wiring including connectors is probably the easiest so start there. Also I'd guess that you might get a reset by disconnect the battery for a while but ensure that you have any radio code first. 1 Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 17, 2016 Author Share Posted April 17, 2016 I'm afraid to say we did buy from trade but as we can now see a very dodgy one... They claim nothing is wrong when it clearly is they fitted a new fuel filter then don't know what else to do or try hence now taking it to a mechanic we know who thought could have been the maf filter but after disconnecting it still done it. Air temperature is the minus figure. Thank you for your reply ill give it a try! Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 21, 2016 Author Share Posted April 21, 2016 All checked an all wiring fine, still doing it every 181 miles driven... any thing else to try? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted April 21, 2016 Share Posted April 21, 2016 I would replace the sensor it self, after that do an oil change for peace of mind likely the dealer didn't bother with that either. See how it goes from there, if it's still being a bit dodgy go to a different garage don't tell them anything about you've only just bought it explain what's wrong and they might be able to help you. Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 21, 2016 Author Share Posted April 21, 2016 Thank you for your advise. Will give it a go with the oil change and new sensor. We've gone to another garage and they are the ones who found out the temperature problem. They've had it in diagnostics whilst the car is in its jumping mode and loss of power and nothing is coming up and all pressures are normal - it's got us all a bit stumped. Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 oil changed and sensor and still the same!! We've phoned ford and they don't have any idea why it's doing it either! Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2016 Share Posted April 23, 2016 so the air temp sensor is still showing -56? and when you say air temp do you mean intake air temp? and what engine, 1.6,1.8 or 2.0? Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 2.0. I'm not sure he said it was reading that temperature which it shouldn't be.... Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 It's a new sensor on now so haven't had retake on temperature. Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2016 Share Posted April 23, 2016 did you change the sensor or a garage ? after replacing sensor it should have been checked that it was reading correctly. thats what needs doing first before doing anything else. Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 Garage done it, nothing was said just that it wasn't the problem Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2016 Share Posted April 23, 2016 thats not very usefull then, i would have thought they had said temp now reading ok and still you have problem, or still reading -56 and you still have a problem and i hope they changed the right sensor, 2 sensors very close to each other, one is iat sensor , and other is map sensor. or have they changed the maf sensor next to air filter? Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 Maf sensor was changed. Spent a lot of money trying to fix it that's why came on here as got a baby on the way in august so need it sorted and no one seems to know what todo at either garages... It started to jump as I was gojng to stall but now it jumps few times then looses power (foot on accelerator nothing happens) then will kick in but still jumps. Sometimes if you take keys out and lock the car it will stop until next 180 miles driven but sometimes it will keep doing it for the rest of the day but then following day will drive fine Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 *as if It was going to stall* Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted April 23, 2016 Share Posted April 23, 2016 Have you tried plugging in a ELM cable and checking for codes? Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 Yes absolutely no codes show up at all not even when in the jumping mode Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2016 Share Posted April 23, 2016 so the mass air flow sensor was changed due to -56 intake air temp? that could why it hasnt fixed it, perhaps the intake air temp sensor should have been changed instead. as ryan said , think you need a bluetooth or usb adapter and torque pro or forscan etc to diagnose yourself. Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 23, 2016 Author Share Posted April 23, 2016 Think I will and also have a look at the intake air sensor too. too . Thanks for all your help and quick responses Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2016 Share Posted April 23, 2016 what code reader do you have? if you can read live data, bring up the iat sensor and see what temp it is Quote Link to comment Share on other sites More sharing options...
kevb2016 Posted April 25, 2016 Author Share Posted April 25, 2016 I haven't got any readers but rely on my mate who has his own garage and all the readers who has been helping me Quote Link to comment Share on other sites More sharing options...
