Ford Ka
3 replies to this topic
#1 amanda
amanda
    Member
  • New Member
  • PipPip
  • 15 posts
  • Ford Model: streetka
Posted 24 October 2009 - 10:39 AM
Hi i wonder if anyone has any ideas as to what is wrong with my baby.
Aprox 6 months ago i had both wishbones replaced, now i am getting the same noise again when going over bumps at low speed. The noise seems to be comming from the front left hand side. Do you have any ideas of what it could be and how much it might cost.
Cheers
Amanda :(
Have something to contribute?
#2 delboy
delboy
  • True Ford Enthusiast
  • 536 posts
  • Name: martin
  • Ford Model: c-max ghia 1.8 petrol /ka 1.2 mk2
  • Year: 2004
Posted 24 October 2009 - 05:30 PM
i would have the drop links looked at as they go aswell
a garage will charge you a small fortune to do them
ask a fried to do them for you
a wishbone should cost you about 10.00 then 20 mins to replace it.
i have a spare one here if you want it as i just done 1 of mine but purchased 2 of them
email me where you are & i will do it for you if your in my area & charge you 10.00 for the part & fitting it
otherwise contact me on
on my email & i can post it to you
i am pretty sure it's this part as i just done both lower suspensin/wishbones.
ford will charge you about 40.00 for this part + fitting
to check if it's the drop link ask a friend to
hold the link/ it looks like a bar thet comes off the suspension & drops to the wheel about 6mm in diamitor
get him/her to shake it & you push down on the wing of the car & if she/him feels any movement from either side it's defo gone
#3 sky pilot
sky pilot
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Ford Model: Ka
Posted 25 October 2009 - 12:34 AM
I had a awful sqeeking sounded like a spring creeking all the tim from the front left, turned out it was the suspection link just needed oiling LOL
#4 gaz6076
gaz6076
  • New Member
  • 448 posts
  • Ford Model: Mk5 Fiesta
Posted 25 October 2009 - 07:07 PM
Could be a number of different things. As already mentiond droplinks are a favourite and can be checked easily with the help of a friend as delboy describes.
Another easy thing to check that quite often goes is the top strut mounts. Give each spring a good tug back and forth. Any movment would suggest this is the cause.
Not what you're looking for?
