Madge Posted April 20, 2016 Share Posted April 20, 2016 I often cannot,release the key quickly enough when starting the car so I get the grinding noise of the starter still engaged. This is a new development and my partner has the same problem (not my slow reactions). In the past I could release the key as soon as I was aware the engine had fired but now I have to give a quick flick of the key and even then I sometimes get the grinding as the engine fires. Can anyone explain what could cause this please? Quote Link to comment Share on other sites More sharing options...
Mariner Posted April 21, 2016 Share Posted April 21, 2016 Sounds like either the helix gear on the starter motor is sticking / damaged - or worse case the flywheel gear teeth are damaged. I think it will need the starter motor removing for a proper diagnosis. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 21, 2016 Share Posted April 21, 2016 Makes a change to all the slow starting threads on here lol! Most likely the starter getting stuck as above though. Quote Link to comment Share on other sites More sharing options...
Madge Posted April 21, 2016 Author Share Posted April 21, 2016 Thanks guys - that makes sense. An easier and cheaper fix than a lot of reluctant starting problems!!! (unless its the flywheel ring gear) Quote Link to comment Share on other sites More sharing options...
