MM92 Posted April 22, 2016 Share Posted April 22, 2016 Hi all, Today the battery light started appearing on the dashboard when I was in natural sat at traffic lights. The light would then go out once I got into first and pulled away. There's been no loss of power etc when the light is on and off. windows, radio, wipers etc all the same speed etc. Plus, the last couple of days the revs have got stuck at the 1,200 mark before making its way down to 8/900 (normal) when I drop into neutral. (Again, no issues on power or gear changes). Would these be linked or well timed separate issues? Any ideas on what could be causing it/them? Thanks! Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 22, 2016 Share Posted April 22, 2016 could be linked when you start the car do the dials sweep? battery light will either be a battery fault alternator or dash cluster any garage will do a free battery and alternator test its also possible the alternator belt is slipping and old .you can do the dash test check batt voltage at starting 12.5v engine running in neutral 14v minimum any Quote Link to comment Share on other sites More sharing options...
MM92 Posted April 22, 2016 Author Share Posted April 22, 2016 1 hour ago, artscot79 said: could be linked when you start the car do the dials sweep? Battery light will either be a battery fault alternator or dash cluster any garage will do a free battery and alternator test its also possible the alternator belt is slipping and old .you can do the dash test check batt voltage at starting 12.5v engine running in neutral 14v minimum any Yup, the dials all sweep and run without any issues. I'll take it to the garage tomorrow - I got the battery Jan 2014. Thanks. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 22, 2016 Share Posted April 22, 2016 if the dials sweep on start up that means the battery is low the sweep is a self diagnostic that only happens when the battery is low it shouldn't sweep at all unless you do dash diagnostics make sure The battery is a calcium or silver calcium a lead acid battery wont work Quote Link to comment Share on other sites More sharing options...
MM92 Posted April 23, 2016 Author Share Posted April 23, 2016 Just had it checked. The battery was slightly low and the alternator is also slightly low on the power it's giving. So going to swap the alternator. From memory it's a Platinum silver battery. Not sure if this linked to the higher revs in neutral but the battery light is the main concern at the moment. Thanks Quote Link to comment Share on other sites More sharing options...
MM92 Posted May 2, 2016 Author Share Posted May 2, 2016 UPDATE: Got the alternator changed and we're all good! Since being changed the revs have gone back to idling normally and not sticking. Quote Link to comment Share on other sites More sharing options...
