Bucksend Posted April 26, 2016 Share Posted April 26, 2016 Hi, I am about to hard wire my dash cam and wanted to ask if anyone knew of an easy to get to ignition fed live? I have a hard wire kit which did not come with the fuse adapter/piggyback end, I just have bare ends. One I know t bolt to the body - not problem. But where can I put the live? I have a 57 plate focus. Thanks in advance, Adam Quote Link to comment Share on other sites More sharing options...
Micro Posted April 26, 2016 Share Posted April 26, 2016 I'd buy a proper fuse tap, they're only a few bob and it'll be an easier fit. Quote Link to comment Share on other sites More sharing options...
blue crush Posted April 27, 2016 Share Posted April 27, 2016 Or tap into the radio ignition feed. Not sure which colour or wire it is tho at top of my head Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 27, 2016 Share Posted April 27, 2016 As a 57 plate it could be either a mk2 or mk2.5 so depending on which it is will determine which fuse you should tap off. I generally use the rear wiper one on the glovebox board as it is ignition live only. If you aren't sure which one this is have a look at my guides link under my posts when viewed on a PC. I have full listings of mk2 & mk2.5 fuses to assist. Run the earth to any body mounted bolt/screw in the footwell, the mounting bolts for the footwell fusebox bracket are very handy to access. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
higgsy Posted April 28, 2016 Share Posted April 28, 2016 i used 108 on my mk2.5, feeds retrofitted auto dipping rear view mirror and dash cam Quote Link to comment Share on other sites More sharing options...
