Oil sensor light not turning off
4 replies to this topic
#1 PMJ
PMJ
    Newbie
  • Pip
  • 2 posts
  • Ford Model: 1.8 Zetec petrol estate
Posted 03 June 2008 - 08:41 AM
My oil sensor light started to flash during some very wet weather last week, before switching over to being on constant. I checked the oil - it was a little low - and added some more, but the light was still on. I re-checked and found that I'd over-filled (even though I hadn't added that much) and let some out so that the oil is now at the correct level, but the warning light is still on. Short of there being a problem with the sensor, I'm now out of ideas.
Has anyone else experienced anything similar? Or any guesses as to what it could be?
#2 old cruiser
old cruiser
  • 94 posts
  • Ford Model: wife's 2006 Fiesta 1.25 [Climate]
Posted 03 June 2008 - 12:56 PM
If you can locate the sensor, I would suggest removing the connector and use some WD-40 or the such like to dispell water that might have got into the connector etc. causing it to short circuit and see how you go from there at worst case you may need to replace the sensor, at the same time might also be worth checking with a multimeter on the connector pins just to make sure there isn't a short circuit there i.e an issue with the wiring (hopefully this won't be the case)
Cheers Pete
#3 PMJ
PMJ
    Newbie
  • Pip
  • 2 posts
Posted 03 June 2008 - 08:58 PM
Hi Pete,
I'll have a look! Many thanks.
Neil
#4 hotashel
hotashel
  • 79 posts
  • Gender: Female
  • Ford Model: mark 4 escort xr3i cabaret
Posted 04 June 2008 - 05:42 PM
My cabby oil light flashes in hot weather also has done for 5 years, im used to it now but have been told that it is the sensor lol
H
#5 old cruiser
old cruiser
  • 94 posts
Posted 04 June 2008 - 06:37 PM
Hi Pete,
Neil
No problem mate, let us know how you get on.
Cheers Pete
