the_ace Posted October 27, 2009 Share Posted October 27, 2009 Hi ya'll! I've just picked up asilver 5 door Focus 1.8 Zetec on an S plate at the auction for 500 notes. It needs a clutch so that will be getting sorted next week. It also needs a spare key as it currently only has one! Is this going to be a simple case of buying a new fob off eBay getting it cut then programming it myself? Or am i going to need to go to ford?:( Loving the handling already! Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted October 27, 2009 Share Posted October 27, 2009 Hi and welcome to the club. Getting the clutch done is going to be a back street garage job. Wouldn't take it to ford for that as they will charge you a fortune. As you say you can get a fob and key of eBay and get it cut, however it won't start the car or operate the remote central locking unless you get it programmed. It can somtimes be done without taking it to ford if the car hasn't been 'locked out' by ford. When you get your new key post back on here and I'll give you a guide Quote Link to comment Share on other sites More sharing options...
the_ace Posted October 28, 2009 Author Share Posted October 28, 2009 Hi and welcome to the club. Getting the clutch done is going to be a back street garage job. Wouldn't take it to ford for that as they will charge you a fortune. As you say you can get a fob and key of eBay and get it cut, however it won't start the car or operate the remote central locking unless you get it programmed. It can somtimes be done without taking it to ford if the car hasn't been 'locked out' by ford. When you get your new key post back on here and I'll give you a guide Thanks for the quick reply mate, i'll do that once i get a key. Its away to the garage now, mechanic reckons it could be £400 for the clutch! I saw them on eBay for £60 ish so may have to look into DIYing it. Hopefully it doesn't need much more done, theres a knock from the front which he's going to look at and a major service so fingers crossed it will be all good by next week. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 30, 2009 Share Posted October 30, 2009 Thanks for the quick reply mate, i'll do that once i get a key. Its away to the garage now, mechanic reckons it could be £400 for the clutch! I saw them on ebay for £60 ish so may have to look into DIYing it. Hopefully it doesn't need much more done, theres a knock from the front which he's going to look at and a major service so fingers crossed it will be all good by next week. did it come with the red key if not you wont get anything reprogrammed to the car which means reprogramming a new key wont work ford will need to connect it up to get the code then reissue new cut keys a costly job im afraid Quote Link to comment Share on other sites More sharing options...
catch Posted November 22, 2009 Share Posted November 22, 2009 did it come with the red key if not you wont get anything reprogrammed to the car which means reprogramming a new key wont work ford will need to connect it up to get the code then reissue new cut keys a costly job im afraid artscot79 Don't you just love it when "thread starters" don't come back to you with the follow up. When you have been good enough to reply to their enquires. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 22, 2009 Share Posted November 22, 2009 im used to it on the passat forum people buy stuff with no research then expect things to be cheap and easy to fix, they dont like it when its not the case. like the fiats his s reg should have a red key probably the reason its at auction is it doesnt so when the key wears out hes stuffed, not so bad with the later ones that dont use the red keys like my one i have the master and the remote key made damn sure it came with it. Quote Link to comment Share on other sites More sharing options...
