GTTDI130 Posted May 20, 2016 Share Posted May 20, 2016 Hi all I have a bad smell coming through the vents when the a/c is on. My car has the manual a/c unit and I think this smell may be due to q blocked drain pipe as I had water dripping from the air outlet in the foot well. Can anyone help me with regard to the location of the drain pipe for the A/c system Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
iantt Posted May 20, 2016 Share Posted May 20, 2016 This is cmax but sure drain is in same area. Quote Link to comment Share on other sites More sharing options...
GTTDI130 Posted May 20, 2016 Author Share Posted May 20, 2016 That's great thanks I think most of the layout is the same the s max is just stretched out from the c max I will check this in a bit Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
NorJaime Posted December 17, 2020 Share Posted December 17, 2020 Hi, I'm having trouble removing that drain pipe to unclog it... it seems hard to remove, can I force it? Is there a technique to get it off without breaking it, just seems a bit stiff to me Quote Link to comment Share on other sites More sharing options...
karl1171 Posted July 16, 2021 Share Posted July 16, 2021 Thanks this was really helpful. With regards to getting it off, i rolled the black rubbery part down the top white plastic part, also helps for when you're putting it back. Top tip have a towel handy- I didn't, but at least had my phone! Quote Link to comment Share on other sites More sharing options...
