mrmetallica Posted May 22, 2016 Share Posted May 22, 2016 after weeks of pulling my hair out and pulling the car apart because of engine light on also abs light on hand brake light on speedo not working. i found the problem i was getting code u121 i think it is the answer simple .a fuse i didnt know was there.who would believe it .lets hope others with the same problem has the same the only thing now is when i turn on ignition i get power steering failure .no codes any ideas there is normaly a black cover you have to lift Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 14, 2016 Author Share Posted June 14, 2016 i sorted out why the engine light and esp light was staying on. but on friday out with my daughter the engine malfunction warning comes on into limp mode .got home ok was all ok again and then today going to see my other daughter and it comes on again four time in a very short time .it seemed to sort itself out and got there and back . what is it that goes on the clocks ? im thinking of getting another set to see if it goes away Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 15, 2016 Share Posted June 15, 2016 the circuit board nasty solder breaking etc as the cluster is part of the can system these breaks etc cause all the symptoms that fuse is smartcharge 10amp fuse by the way 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 15, 2016 Author Share Posted June 15, 2016 6 hours ago, artscot79 said: the circuit board nasty solder breaking etc as the cluster is part of the can system these breaks etc cause all the symptoms that fuse is smartcharge 10amp fuse by the way i dont understand the fuse bit whats that about Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted June 15, 2016 Share Posted June 15, 2016 Probably a (low power) supply to the electronic module in the smart charge system. It is way too small for the actual charge currents. Charge may revert to non-smart without it, but I would expect an error indication of some sort. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 15, 2016 Author Share Posted June 15, 2016 1 minute ago, Tdci-Peter said: Probably a (low power) supply to the electronic module in the smart charge system. It is way too small for the actual charge currents. Charge may revert to non-smart without it, but I would expect an error indication of some sort. straight over my head lol sort of understand Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 15, 2016 Share Posted June 15, 2016 the fuse is required for the smart charge if that blows the smart charge isn't working as it should Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 15, 2016 Author Share Posted June 15, 2016 Just now, artscot79 said: the fuse is required for the smart charge if that blows the smart charge isn't working as it should where is the fuse then ? the car seems all ok again Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted June 15, 2016 Share Posted June 15, 2016 You put a red ring round it in your 1st photo! Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 15, 2016 Author Share Posted June 15, 2016 5 minutes ago, Tdci-Peter said: You put a red ring round it in your 1st photo! ohh thats what it is lol.im not getting the same lights on now its just the engine malfunction flashes up goes into limp mode Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 15, 2016 Share Posted June 15, 2016 its pin3, reference voltage for the pcm monitoring battery voltage ! Its fed from a fuse in the CJB. The 10 amp you circled and a high resistance on the fuse contacts causes a volt drop, and the smart charge drops out ! 7 minutes ago, Tdci-Peter said: You put a red ring round it in your 1st photo! Quote Link to comment Share on other sites More sharing options...
