Sophiemg1 Posted May 22, 2016 Share Posted May 22, 2016 Ford Focus zetec climate 2006 turbo 1.8 young female driver clueless about cars and dads away could be over thinking but here we go.... so when I change gears they a vibrations noise/feeling not coming from under bonnet coming from else where. It happens starting from 2ND gear change up until about 2rmp then stops until I do next gear change and happens again. Am I just overthinking this? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 6, 2016 Share Posted June 6, 2016 Hi Sophie (Impersonates a mechanic sucking in his breathe!) to be honest, those engines are pretty bullet proof, and you can get a lot for them, but it all depends on the mileage. The Dual Mass flywheel can be a bit of a nightmare, and vibration is often the first sign that it is starting to misbehave and may need replacing.... What is the mileage? It could also be something as silly as a clutch thrust bearing, but in all honesty, if your going to replace the clutch, replace the DMF as well, if you plan on keeping that car, its worth the effort. Quote Link to comment Share on other sites More sharing options...
