Jonanstee Posted May 30, 2016 Share Posted May 30, 2016 Hey guys. I wrapped my dash a few days ago. I've been down by the beach for the past few days so it's really hot and I've just checked my car to realise that all around the circle dials the wrap has come out. Any idea what I can do to get it to stay in? Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 30, 2016 Share Posted May 30, 2016 I found that cutting the circles like a pie and folding each triangle back worked well, then glued the triangle segments back. The only issue I have found is the garage door, the small indent lasted for about 6 months and recently popped up again, cant get it to stick back now Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 30, 2016 Share Posted May 30, 2016 Buy better vinyl! The normal stuff isn't designed to withstand the ~30c heat or car interiors in the sun. 1 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 30, 2016 Share Posted May 30, 2016 any suggestions? I have some off cuts to redo the wee hatch but when it happens again ill need to redo the whole lot to get it looking the same. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 30, 2016 Share Posted May 30, 2016 theres a few things first lay the vinyl on covering everything use heat to get the glue to set not too much though then use s craft knife never cut around the hole instead on circular areas in particular as said from the centre cut a pie use a little bit of heat and fold n shape on the back apply a bit of heat to ensure all the glues activated....plenty of you tube vids it just takes patience and practice and good vinyl really cheap stuff I just that and is harder to work Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted May 30, 2016 Share Posted May 30, 2016 As quoted by dee82 just get the wrap overlapped around they back of the panel as best you can, once the wrap is set hard to shape will tuck in great, better wrap is slightly beneficial but mostly down to how its applied 1 Quote Link to comment Share on other sites More sharing options...
