Hi, a problem has just developed with my Fiesta. No matter what position I put the fan direction control knob in it stays stuck on demist. Clearly it is a problem with the knob, I was wondering if this is an easy problem to fix or will I have to take it in for repair?
Fiesta Fan Direction Control Broken
Started by Max, Jun 08 2008 01:31 AM
4 replies to this topic
#1
Posted 08 June 2008 - 01:31 AM
#2
Posted 08 June 2008 - 05:12 PM
it may be jammed with a bit of debris.
is it mechanical or electronic?
#3
Posted 08 June 2008 - 06:45 PM
It's definitely not an eletrical problem, it has to be the knob itself. I can keep turning the direction control knob around and around, so clearly the knob isn't connected properly. Should I just unhuck the center console and to see if I can reconnect it.
#4
Posted 09 June 2008 - 06:08 PM
the knob sounds broken.. can you pull the knob off? (said the actress to the bishop LOL)
bit of glue may do the trick
#5
Posted 11 June 2008 - 12:55 AM
Right fixed it, the previous owner had put their own CD head unit in and whilst doing it they must have detached a metal cable that runs from the control nob to the right back of the centre console. All I had to do was plug it back in, and now I have direction control
Hope this helps anyone who has similar problems
