MaxDee Posted June 13, 2016 Share Posted June 13, 2016 Hi, have noticed a slight gearbox oil leak from the driveshafts. It's not dripping but noticeable. Is this normal as I never notice this on my other Fords that I owned. Also, anyone knows where the gearbox oil filler is as could not see it anywhere? Quote Link to comment Share on other sites More sharing options...
iantt Posted June 13, 2016 Share Posted June 13, 2016 is it dripping oil or just damp around the seal? "Very light oil mist at the outer diameter of the seal housing is remaining oil from the transmission test inspection. This amount of oil will NOT increase with milage, is normal. Using a clean cloth wipe away the oil mist and do NOT renew the halfshaft seal. " Quote Link to comment Share on other sites More sharing options...
MaxDee Posted June 14, 2016 Author Share Posted June 14, 2016 17 hours ago, iantt said: is it dripping oil or just damp around the seal? "Very light oil mist at the outer diameter of the seal housing is remaining oil from the transmission test inspection. This amount of oil will NOT increase with milage, is normal. Using a clean cloth wipe away the oil mist and do NOT renew the halfshaft seal. " Hi Ian, it is not dripping and it's damp around the outer diameter of the seal. It is wet around the area which i wiped and will check again in a week or two. Shouldn't this oil have dried out after 3 years and 32K miles? Quote Link to comment Share on other sites More sharing options...
iantt Posted June 14, 2016 Share Posted June 14, 2016 oil doesnt dry,water does. Quote Link to comment Share on other sites More sharing options...
MaxDee Posted June 14, 2016 Author Share Posted June 14, 2016 That's a point!! Do you know if theses cars have gearbox oil filler or do you have to pull the shaft out to fill. I could not see one but maybe i just not look at the right places. Quote Link to comment Share on other sites More sharing options...
iantt Posted June 14, 2016 Share Posted June 14, 2016 think yours is the b6 box, so there should be a level plug, if you find it, dont expect to find the oil level at the plug, theres a procedure for filling and checking level. 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted June 14, 2016 Share Posted June 14, 2016 On 13 June 2016 at 4:02 PM, MaxDee said: Hi, have noticed a slight gearbox oil leak from the driveshafts. It's not dripping but noticeable. Is this normal as I never notice this on my other Fords that I owned. Also, anyone knows where the gearbox oil filler is as could not see it anywhere? Had mine replaced after getting an advisory on last years MOT, I've got a mk2 facelift focus and mine weren't actually dripping either. 1 Quote Link to comment Share on other sites More sharing options...
Suejr Posted September 1, 2023 Share Posted September 1, 2023 Hi just a quick question. I replaced my gearbox driveshaft on my fiesta mk7 1.4tdci 2008 but I think I pushed it in too far, is it possible to do this? It started to leak again. So I’ve took it out and I’m going to put another one in tomorrow. Do I keep it flush with the gearbox housing or tap it in as far as it goes? Quote Link to comment Share on other sites More sharing options...
