Coolbluelights
mondeo 2.0 leaking coolant
i have a 1997 ford mondeo 2.0 petrol and i have a coolant leak from a metal pipe underneath that has corroded and develovd a pin hole and is now leaking coolant at an alarming rate, thing is i cant find a new one anywhere, does anyone have any advice?
cheers
Bradley
If you PM me your VIN I'll have a look on microcat for you tonight.
A wider area photo of the position of the pipe in relation to the engine bay would also be of great use in locating the right bit for you.
Sent from my SM-G930F
Those pics are upside down, the pipe is right at the bottom & under the radiator and in front of the sump pan.
Look at the part image numbers ringed in red.
Your VIN says that they are the relevant parts to fit your car.
Part 1 - Finis Code - 1021708 - £ 27
Part 2 - Finis Code - 1086903 - £ 31
Part 4 - Finis Code - 1068991 - £ 16
Part 7 - Finis Code - 1061523 - £ 66
Part 8 - Finis Code - 1058652 - £ 44
Note - All Prices are approximate only.
Pick the part that matches your damaged pipe.
The ones crossed out in red are not applicable to your car as determined by your VIN.
Take the relevant Finis code to a Ford Dealers Parts Counter, they usually order in twice a week.
