mjt Posted July 16, 2016 Share Posted July 16, 2016 Can anyone tell me the type number of spark plugs used on the 1.8HE engine. Neither my Haynes nor the Ford owners guide specifies it. I've done a quick search of this forum but can't find anything. Also which would be the best make to go for and what is the torque figure for tightening them? Thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 16, 2016 Share Posted July 16, 2016 12 nm, ford plugs are agfs 22 ipj Quote Link to comment Share on other sites More sharing options...
mjt Posted July 16, 2016 Author Share Posted July 16, 2016 Thanks Ian. Would you advise going for genuine Ford items or could I get e.g Bosch or NGK? Quote Link to comment Share on other sites More sharing options...
iantt Posted July 16, 2016 Share Posted July 16, 2016 get whatever plugs you like really, think there ngk that ford use nowadays in ford packaging, Quote Link to comment Share on other sites More sharing options...
mjt Posted July 16, 2016 Author Share Posted July 16, 2016 I extracted a plug which had a FoMoCo number 5MG5-12405-AA. Googled that and found an NGK TR6AP-13 which was also on the plug I'd taken out so you're probably right. I've also managed to find a Bosch Double Platinum 0 242 240 620. The plug I took out looked pristine and the gap was still precisely 1.3mm even though I think they're original and the car's done a bit over 30K. It's going in for a service so may tell the garage to leave them a bit longer as it's running sweetly. When I refitted it 12NM seemed barely more than finger tight so I nipped it up just a smidge tighter. I've since found the NGK and Bosch specs allow up to nearly 20NM in an alloy head. Anyway thanks for the advice Ian. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 16, 2016 Share Posted July 16, 2016 yep, 12nm it should be, on my ecoobost its 13nm. as you say it doesnt seem enough, but even at that torque they dont come loose. Quote Link to comment Share on other sites More sharing options...
