Shooda Posted July 24, 2016 Share Posted July 24, 2016 Hi guys Got a 2015 Mondeo 180 and a couple of times in the last month, there's been oil on the drive. The first time I thought is was a friends old car who had visited as I couldnt see anything underneath mine, but I noticed some again this morning and could see drips hanging from the engine tray. I'm obviously going to take it to Ford but has anyone had experience if this before? I had old cars as a kid and normally if you had a leak, it leaked all the time Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted July 24, 2016 Share Posted July 24, 2016 have you had it serviced recently? Quote Link to comment Share on other sites More sharing options...
Derek 40 Posted July 31, 2016 Share Posted July 31, 2016 Did you get in sorted ?? As mine is doing the same Quote Link to comment Share on other sites More sharing options...
iantt Posted July 31, 2016 Share Posted July 31, 2016 derek, have you had your car serviced recently? Quote Link to comment Share on other sites More sharing options...
Derek 40 Posted July 31, 2016 Share Posted July 31, 2016 Yes Quote Link to comment Share on other sites More sharing options...
iantt Posted July 31, 2016 Share Posted July 31, 2016 i would take it back asap. the garage needs to check the oil filter is tightened correctly , just !Removed! it on by hand is not enough on this engine for some reason, and can leak. failure to have it tightened correctly can result in severe oil leak at first then engine siezing. ( worst case senario) Quote Link to comment Share on other sites More sharing options...
Derek 40 Posted July 31, 2016 Share Posted July 31, 2016 39 minutes ago, iantt said: i would take it back asap. the garage needs to check the oil filter is tightened correctly , just !Removed! it on by hand is not enough on this engine for some reason, and can leak. failure to have it tightened correctly can result in severe oil leak at first then engine siezing. ( worst case senario) Thanks I was going to the main dealer tomorrow Quote Link to comment Share on other sites More sharing options...
