wilto Posted July 28, 2016 Share Posted July 28, 2016 Hi guys, have had a strange noise coming from my car for a few months now, it's most notable when the car is cold, it sounds like a cross between an old fashioned whistling kettle starting to boil and the sound you get when the AUX is selected on the radio. you can hear it sometimes on tick over but it's most prevalent when the car starts moving. I get a high pitched noise then it goes lower then higher then nothing, it's totally random, checked the dive belt and tensioner, all seem OK. Has anyone else experienced something similar, thank in advance guys, Chris. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 28, 2016 Share Posted July 28, 2016 Not experienced it, but my first thought was alternator. Does the noise change with revs at stationary? I.e. is it linked to engine speed or road speed? Quote Link to comment Share on other sites More sharing options...
wilto Posted July 28, 2016 Author Share Posted July 28, 2016 No it doesn't, I thought alternator as well, can't really rule it out though, it's guite quiet on tick over, just the odd whistle, it weirded its not a constant noise either when moving, when the car is warm it's gone. I took a friend of mine who's a mechanic for a short spin in the works car park an he said I MIGHT be the stainless steel exhaust making the noise as its from the cat back. Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 28, 2016 Share Posted July 28, 2016 rust on the brake disc Quote Link to comment Share on other sites More sharing options...
wilto Posted July 28, 2016 Author Share Posted July 28, 2016 No it's definitely a engine bay related noise. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 28, 2016 Share Posted July 28, 2016 water pump Quote Link to comment Share on other sites More sharing options...
wilto Posted July 31, 2016 Author Share Posted July 31, 2016 On 28 July 2016 at 9:15 PM, iantt said: water pump Hmmm hadn't thought about that, why would it be more noticeable when moving though? Quote Link to comment Share on other sites More sharing options...
iantt Posted July 31, 2016 Share Posted July 31, 2016 no idea why you hear it more while moving, but as you say it does it stationary also, so it has to be engine mechanical side under bonnet. water pumps can make a squeaking type of noise esp from cold and get quieter or stop when warm. its the seal in the pump that squeaks. first thing i would try from cold is drop the aux belts off and see if noise has gone or not, that will determine where to start to look. also the top tensioner pulley sometimes make a noise/rattle . Quote Link to comment Share on other sites More sharing options...
wilto Posted August 1, 2016 Author Share Posted August 1, 2016 That's a good call Ian, I'll try that first I think, thanks pal 👍 Quote Link to comment Share on other sites More sharing options...
