Dropzone Posted July 29, 2016 Share Posted July 29, 2016 tried to make as short and to the point as possible bare with please聽馃槣 I have been having a few problems with my 聽06 plate 1.6 focus zetec, the much talked about engine system fault error, usually followed by 'reduced acceleration'. The car was booked in to be diagnosed however i decided to take out the cluster and have a bit of a fiddle which seemed to miraculously cure the problem for about a month! However the fault has returned and seems to be slowly getting worse over the last couple of days until today it showed the error and failed to start full stop for an hour and a half (started after that and drove it home). I'm attempting to take the cluster apart and clean the circuit board with a contact cleaner however I can't seem to access the front of the circuit board as compared to the ones I've seen from researching it is back to front in the casing?? I've read to prize the needles off with a spoon and access it that way however it feels to me like it's going to hurt the internals of it. I've attached a few pictures below, all feed is welcome as I am well and truly stumped 馃槉 Also聽the聽very back part of the plastic casing was caked with a dusty black substance, could this be a cause or something to do with it?聽 Quote Link to comment Share on other sites More sharing options...
BOF Posted July 29, 2016 Share Posted July 29, 2016 I聽don't think that your dusty substance _is_ your fault but if something has burnt out that could have caused that stuff to be deposited. You'll probably only find out once you get at the printed circuit board. That round pattern that looks as if it is something to do with the rpm/speed dials is just weird. I'm sure that there is a reason but it doesn't spring immediately to mind. The other thing to keep In mind Is that a lot of failures are caused by connections and wiring so it always worth looking there. 聽 Quote Link to comment Share on other sites More sharing options...
Dropzone Posted July 29, 2016 Author Share Posted July 29, 2016 I wasn't entirely sure if the dust was related but it seemed suspect or some sort of contaminant, the real issue im聽having is getting to the face of the printed circuit board. I know it may be a long shot but do you have any experience in this (removing the needles and other parts preventing me from opening it up) or know of a tutorial video for a mk2 model?聽 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted August 1, 2016 Share Posted August 1, 2016 On 29/07/2016 at 4:48 PM, Dropzone said: I can't seem to access the front of the circuit board as compared to the ones I've seen from researching it is back to front in the casing?? I've read to prize the needles off Have you had any success yet? (Missed your post until now) If not see my pdf: http://www.fordownersclub.com/forums/applications/core/interface/file/attachment.php?id=40491 It is probably a bad solder joint. Needs a touch with a soldering iron. Contact cleaner won't help. 聽 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted August 3, 2016 Share Posted August 3, 2016 On 29/07/2016 at 4:48 PM, Dropzone said: all feed is welcome as I am well and truly stumped Any feedback or progress? Peter. Quote Link to comment Share on other sites More sharing options...
Dropzone Posted February 26, 2017 Author Share Posted February 26, 2017 Yes I took the cluster into an autoelectricians place which specialises in these types of issues and it was indeed the soldering. Hasn't missed a beat since!聽 (Apologies for no updates and cheers!) 1 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted February 26, 2017 Share Posted February 26, 2017 35 minutes ago, Dropzone said: it was indeed the soldering. Hasn't missed a beat since!聽 (Apologies for no updates and cheers!) "common faults" are actually quite rare!, but the 2006 Focus IC soldering fault is a bit of an exception. The number of these must be really huge, I am sure we only see the tip of the iceburg on this site. I am very pleased it has been resolved without excess cost , and it is even better to get the feedback. Thanks for that. Peter. Quote Link to comment Share on other sites More sharing options...
