No Cranking, with flashing pats light
alz
 Share
Hi All
My focus MK2  won't start, No crank and the pats light flashing, as any one had this problem. this is how the clocks go, the pat light flashes fast. then after a short time the pats light flashes 1 then 6 flashes and keeps repeating 1 then 6 flashes.
Link to comment
1 : 6 Faulty link between PATS and EEC v module.
Basically a miscommunication between the ecu and cluster.
I'd get a diagnostic done and go from there.
May be a bad wire or a cluster fault.
Sent from my SM-G930F
Link to comment
Most likely a defective instrument cluster because the display also shows lines instead of the correct values.
  • Like 2
Link to comment
Aye, classic cluster failure.
Link to comment
Yeah, loads & loads!
As Clive & Wilco say, sounds like IC problem, common for 2005/6/7 Focus.
I had it, fixed it for £15, that was for a scanner which is a good thing to have anyway.
They can be repaired for usually <£100.
A garage will usually charge £500 to £800 for a new one.
My fix (and some info) is in: http://www.fordownersclub.com/forums/applications/core/interface/file/attachment.php?id=40491
For info on Forscan, see:
Link to comment
The procedure described in this film only programs the central locking key fob. This has nothing to do with the PATS system or the problems that the topic starter has.
On the Focus MK2/MK2.5 the PATS system can only be programmed softwarematically using a suitable Ford specific diagnostic system that has the ability to program the Ford CODED PATS system.
  • Like 1
Link to comment
Thanks Guys, for all the info,    (Peter, thanks for the link )
  • Like 1
Link to comment
Aw I dunno. Worth a try
Link to comment
Definitely a PATS communication fault as discussed earlier.
RCL settings are a totally seperate circuit.
Send the cluster to this company- http://www.clusterrepairsuk.co.uk/repair/make/ford?utm_source=google&utm_medium=cpc&utm_term=ford%20focus%20dash%20repair&utm_content=Ford&utm_campaign=CRManufacturerKeywords
They will diagnose and refurbish the unit no problem.
Link to comment
I had this, found a blown fuse under bonnet. Replaced and problem gone.
Link to comment
Hi Clive, I have contacted them and waiting for a reply,  will let you know how I get on.
  • Like 1
Link to comment
Hi Guys
took her to ford in the end,  they plugged her in to their computer and found out that there was no power getting to the canbus module, corrosion on the power connection,  this is what was messing the clocks and the pats about,  all running ok now,  price at ford was only  £144.00 :smile:
Thank again.
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
