Airbag light flashing
Robuk
 Share
Hi there all, just bought a 53 plate 1.6 petrol fusion and I've a problem with the airbag light sometimes flashing and sometimes it stops on does anyone have any ideas, also to give it a good clean am I ok to just unbolt the front seats from the floor ( torxs bolts) there doesn't look like there's any wires going to them for airbags
thanks all
Link to comment
I seem to remember that if you're going to take out the seats then I think you need to disconnect the battery before you unplug the wires underneath as you might set the seatbelt pre-tensioners off
Even then you should wait a little while as the system has it's own reserve power source which supplies juice in case of a break in the main electrical supply
Link to comment
Also the Haynes manual admits that this sort of issue might be beyond a DIY mechanic..
Link to comment
  • 1 month later...
After a bit of messing about I've found the fault,it's the wiring under the passenger seat that as far as I know goes to the pre-tensioner on the seatbelt thingy
Thanks for the help folks
Rob
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
