M Lam Posted August 11, 2016 Share Posted August 11, 2016 Hi I just found some water leak from my ford focus today. It is very close to the engine area (I guess). May I know what leaking is that? Engine water? Air con water? I have some picture attached I will be away for 4 weeks after next Monday evening. Do you think is better for me to get this fix as soon as possible or I can wait till 7 Sept? Isn't something serious? Thanks Quote Link to comment Share on other sites More sharing options...
trailertrash Posted August 11, 2016 Share Posted August 11, 2016 Various possibilities... If it's coloured, as in coolant or washer fluid it could be a leak. If it's clear it's possibly condensation from somewhere, probably the aircon. It looks clear, maybe the drain pipe from the aircon has become detached. If it's been raining (not in Devon it hasn't!) it might also be the bonnet seal. Have you recently topped up the washer bottle? There's an overflow which can be mistaken for a leak. 1 Quote Link to comment Share on other sites More sharing options...
M Lam Posted August 11, 2016 Author Share Posted August 11, 2016 I just checked the photos, it is crystal clear. I using the air con today as it is very warm around Buckinghamshire. Do you think this is normal condensation from the air con? Or is better to get someone to check it as soon as possible before the air con leaking badly? I just used Wynns Clean Air (Mint) - Air Con Clearer on last Friday. Do you think this will do any harm to my air con system as I sprayed directly into my vehicle's heater/air conditioning system? According to instruction 'Put the spray in a central position in the passenger compartment of the car or truck cabin'. Quote Link to comment Share on other sites More sharing options...
GaryPL Posted August 11, 2016 Share Posted August 11, 2016 The top 2 photos look like they have a blue tinge... If this is the case, I'd say anti-freeze/engine coolant and trace the leak ASAP. It is normal for the aircon unit to generate moisture. Sometimes if mine has been running for a while on a hot day, I'll find a puddle under my car if I leave it there for a few minutes. Same with my portable home unit. You have to empty that out after a while because of the condensation that builds up inside :) Quote Link to comment Share on other sites More sharing options...
M Lam Posted August 11, 2016 Author Share Posted August 11, 2016 9 minutes ago, GaryPL said: The top 2 photos look like they have a blue tinge... If this is the case, I'd say anti-freeze/engine coolant and trace the leak ASAP. It is normal for the aircon unit to generate moisture. Sometimes if mine has been running for a while on a hot day, I'll find a puddle under my car if I leave it there for a few minutes. Same with my portable home unit. You have to empty that out after a while because of the condensation that builds up inside :) Hi My coolant is red colour. Should it be red instead of blue? Sorry, if I ask stupid question. Should I try to let my engine run when my car still idle for 10 minutes without aircon in morning. If the water still leaking, it mean coolant leaking? 1 Quote Link to comment Share on other sites More sharing options...
GaryPL Posted August 11, 2016 Share Posted August 11, 2016 If your coolant is red, then that's OK. Blue coolant is not uncommon though, hence my suggesting. I doubt leaving your car running will achieve anything. The other thing to look out for is deposits. If it's a fluid from a car, it may leave a residue where it drips onto or leaks from. But it may very well just be the aircon compressor getting condensation :) I don't know where the compressor is on these though. Finding that out may help. 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 12, 2016 Share Posted August 12, 2016 its the aircon drain hole in the drivers footwell at you're left foot if you pull the carpet back the hose is there remove the plastic panel and give it a check 1 Quote Link to comment Share on other sites More sharing options...
M Lam Posted November 7, 2016 Author Share Posted November 7, 2016 Thanks everyone. Confirmed is aircon water Quote Link to comment Share on other sites More sharing options...
