Focus 115 Posted August 18, 2016 Share Posted August 18, 2016 Hi all, I just want to clarify on this. I own a MK1 Ford Focus 1.8 TDCi. I'm planning on replacing the clutch, DMF and release bearing at the same time (all part of a kit). I was just wondering, is the clutch release bearing also known as the slave cylinder, or are they two separate components? Anyone able to shed light on this? It would be greatly appreciated. Many thanks. Quote Link to comment Share on other sites More sharing options...
Russ Posted August 18, 2016 Share Posted August 18, 2016 Two totally seperate components, the 'slave cylinder' is for the clutch fluid. 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 18, 2016 Share Posted August 18, 2016 It's the same unit on the mk1 focus, the slave cylinder and release bearing are combined - also known as a concentric slave cylinder. 1 Quote Link to comment Share on other sites More sharing options...
Focus 115 Posted August 19, 2016 Author Share Posted August 19, 2016 Ah, okay, thank you! Will be replacing the lot in the next month or two. Quote Link to comment Share on other sites More sharing options...
simcor Posted August 20, 2016 Share Posted August 20, 2016 The master cylinder pushes fluid to the slave cylinder which in turn exerts the concentric slave to push against the pressure plate. Master may be a separate unit on the pedal or may be fed from the brake reservoir depending upon vehicle make. Release bearings used to be operated by a fork system with cables until hydraulic concentric slaves became the norm. But the release bearing is now an integrated part of the CSC. Quote Link to comment Share on other sites More sharing options...
