SuperOwls Posted October 18, 2016 Author Share Posted October 18, 2016 1 hour ago, b4zz said: loving the look of the out side very stealth looking. loving the recaro front seats what a nice upgrade. can I ask if they where hard to put in and how long did it take? Cheers mate!! Swapping the seats is 1 of the easiest upgrades to do. Disconnet the battery for 10mins prior to starting so you dont get an airbag fault light on the dash, then it's literally undoing 4 torx bolts, disconnecting the wiring and lifting them out, that's the hardest part cos you need to be careful not to scratch plastic trim or even worse...the paint, especially drivers side with steering wheel in the way, took 20mins max to swap fronts, back seat was a bit more of a pain (see my earlier post). Only other thing to mention is that unless you already have the heated seats you will need switches etc to get them to work, or just use them without the heaters. They really make a difference and can be adjusted much more than standard seats so you get the sporty feel. Main thing for me though is they're wipe clean so no worries about spills etc 1 Quote Link to comment Share on other sites More sharing options...
Joss max Posted October 18, 2016 Share Posted October 18, 2016 Very nice especially the last pic showing made in Sheffield. Could have gone 0114 2 Quote Link to comment Share on other sites More sharing options...
b4zz Posted October 20, 2016 Share Posted October 20, 2016 On 18/10/2016 at 11:15 AM, SuperOwls said: Cheers mate!! Swapping the seats is 1 of the easiest upgrades to do. Disconnet the battery for 10mins prior to starting so you dont get an airbag fault light on the dash, then it's literally undoing 4 torx bolts, disconnecting the wiring and lifting them out, that's the hardest part cos you need to be careful not to scratch plastic trim or even worse...the paint, especially drivers side with steering wheel in the way, took 20mins max to swap fronts, back seat was a bit more of a pain (see my earlier post). Only other thing to mention is that unless you already have the heated seats you will need switches etc to get them to work, or just use them without the heaters. They really make a difference and can be adjusted much more than standard seats so you get the sporty feel. Main thing for me though is they're wipe clean so no worries about spills etc cheers for that and I may do this to mine Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted October 20, 2016 Author Share Posted October 20, 2016 Wasn't keen on the front and rear badges with fly eye wrap so got some gel badges instead, carbon background with red logo's Quote Link to comment Share on other sites More sharing options...
b4zz Posted October 21, 2016 Share Posted October 21, 2016 liking the new badges Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted November 9, 2016 Author Share Posted November 9, 2016 Swapped the dash top storage pocket for the ST gauge pod, I know I won't be able to get them working but it's just for effect at the moment as they look better than the cubby hole. Am looking into getting something mounted in there instead of the factory clocks at some point, maybe a touch screen sat nav if I can find one to fit 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 9, 2016 Share Posted November 9, 2016 Some members here have fitted mobile phones with the torque pro app installed and IIRC someone once fitted a ScanGauge module. 1 Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted November 9, 2016 Author Share Posted November 9, 2016 1 hour ago, Stoney871 said: Some members here have fitted mobile phones with the torque pro app installed and IIRC someone once fitted a ScanGauge module. Thanks, yes I've seen some of them, all good ideas bit I like the sat nav idea, would have to be a small one tho, will post whatever I come up with Quote Link to comment Share on other sites More sharing options...
b4zz Posted November 9, 2016 Share Posted November 9, 2016 4 hours ago, SuperOwls said: Swapped the dash top storage pocket for the ST gauge pod, I know I won't be able to get them working but it's just for effect at the moment as they look better than the cubby hole. Am looking into getting something mounted in there instead of the factory clocks at some point, maybe a touch screen sat nav if I can find one to fit looking good 1 Quote Link to comment Share on other sites More sharing options...
yunii Posted November 12, 2016 Share Posted November 12, 2016 Swapped the dash top storage pocket for the ST gauge pod, I know I won't be able to get them working but it's just for effect at the moment as they look better than the cubby hole. Am looking into getting something mounted in there instead of the factory clocks at some point, maybe a touch screen sat nav if I can find one to fit looking good Looks very good .its hard to get multiplug for this otherwise you could just illumenate it . I once fitted st170 pods in my mk1.5 2.0 esp .bought it with loom already made. It was show purpose only. Then later fitted ghia trip changing colour & adding unique custom made dials face. In my mk2.5 titanium i fitted this Scangauge ii which gives allsorts of readings from ecu. Also a trip computer & fault code reader & eraser. Yunii Sent from my SM-G925F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
gavingilmour Posted December 5, 2016 Share Posted December 5, 2016 Hiya mate spotted the pictures on Morrison's Hillsborough im originally from down that way i live on other side of Sheffield now though! If your ever looking for a spray shop again give daz a ring at "scuffs" and tell him Gavin sent you he will sort you out! Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted December 8, 2016 Author Share Posted December 8, 2016 On Monday, December 05, 2016 at 3:58 PM, gavingilmour said: Hiya mate spotted the pictures on Morrison's Hillsborough im originally from down that way i live on other side of Sheffield now though! If your ever looking for a spray shop again give daz a ring at "scuffs" and tell him Gavin sent you he will sort you out! Nice 1, cheers pal, will bear that in mind, got your message about parts for sale, not got any at the moment but I'm thinking of changing the alloys so mine may be up for sale soon.....if I don't swap for another set Quote Link to comment Share on other sites More sharing options...
gavingilmour Posted December 8, 2016 Share Posted December 8, 2016 I've got a quote unique set of alloys that i don't think Amy focus has so id be reluctant to change but keep me posted on anything elsr buddy!Sent from my E5823 using Tapatalk Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted January 3, 2017 Author Share Posted January 3, 2017 Changed the wheels for the new year, set of Mondeo Titanium 18's instead of the Focus ST's, I prefer the grey instead of the black....for time being anyway 3 Quote Link to comment Share on other sites More sharing options...
b4zz Posted January 5, 2017 Share Posted January 5, 2017 liking the new wheels and one day I may invest in a set of these 1 Quote Link to comment Share on other sites More sharing options...
SuperOwls Posted January 5, 2017 Author Share Posted January 5, 2017 5 hours ago, b4zz said: liking the new wheels and one day I may invest in a set of these Got a good deal with these, £300 for the set, recently refurbished all with matching Falken tyres and they came with a matching 5th wheel too. I sold my ST alloys for the same so didn't cos me a penny and I have a spare alloy now too...happy days!!! 1 Quote Link to comment Share on other sites More sharing options...
b4zz Posted January 7, 2017 Share Posted January 7, 2017 On 05/01/2017 at 2:04 PM, SuperOwls said: Got a good deal with these, £300 for the set, recently refurbished all with matching Falken tyres and they came with a matching 5th wheel too. I sold my ST alloys for the same so didn't cos me a penny and I have a spare alloy now too...happy days!!! wow that was a great price as you say you sold you st wheels for the same price so every one was a winner 1 Quote Link to comment Share on other sites More sharing options...
