mjt Posted August 22, 2016 Share Posted August 22, 2016 The mist jets on my Mk3 are pointing a bit low. I can only see a slot in the plastic, is there a jet concealed inside that I can adjust? I don't want to go poking about with a needle unless I can be sure there is. 1 Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted August 22, 2016 Share Posted August 22, 2016 I'd like to know this too! Fitted Focus mist jets into our Fiesta, they are much better than the horrible standard jet versions but noticed there's a gap in the spray pattern. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 22, 2016 Share Posted August 22, 2016 No they can't be adjusted easily. I have seen people put a sliver or rubber under the leading edge to lift them slightly, but there's no conventional ball jet type thing in there. 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted August 22, 2016 Author Share Posted August 22, 2016 Hmmm. . . . . I suspected as much. I'm not impressed with that. I suppose the idea is they produce such a wide spray pattern that it's not necessary but mine definitely only wet the screen half-way up and the wipers kick in too quickly for the airflow to take the water up the screen. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 22, 2016 Share Posted August 22, 2016 Try moulding a bit of Sugru rubber putty either under the whole piece to raise the nozzle a bit or block some of the spray nozzle itself to push the water out higher. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted August 22, 2016 Share Posted August 22, 2016 someone on here suggested that the mk3 pump was more powerful and might help push it further up, I'm not all that sure it is but its an interesting idea, edit, just saw you have a mk3 so ignore that, mk2 owners might find that a good wee project Quote Link to comment Share on other sites More sharing options...
Shaunbfiestamk7 Posted April 18, 2020 Share Posted April 18, 2020 Hi guys if the spray is up at the top of the screen wrap a cable tie around the tubing to reduce the amount of pressure going threw and will spray lower if yours is spraying only the bottom that's ok as when your driving it will spray further up the screen or put a bigger pump on the washer bottle. Mine sprayed right over the car but while driving hits the screen perfect so put a cable tie on each washer and got it bang on both whilst driving and stationary. Quote Link to comment Share on other sites More sharing options...
sussamb Posted April 18, 2020 Share Posted April 18, 2020 That's completely the opposite of what happens to me? If it sprays towards the top when stationary when moving it'll land lower down, if it's low to start with it'll be even lower when moving. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 18, 2020 Share Posted April 18, 2020 Isn't it amazing that after 100 odd years of automobile development that people still have issues with the most basic of devices a car has... Quote Link to comment Share on other sites More sharing options...
