Georgia0206 Posted August 26, 2016 Share Posted August 26, 2016 So, my mum has an 09 fiesta. When you put the fan on it doesn't matter whether you have it on 1 or 4, it all seems to blow out at the same speed- which is hardly anything! It makes so much noise but doesn't blow any air out! Spoke to a mechanic and he reckons that's just how it is.. Well I say that's BS! Any suggestions? Quote Link to comment Share on other sites More sharing options...
chris23039 Posted August 26, 2016 Share Posted August 26, 2016 Get a second opinion Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Russ Posted August 26, 2016 Share Posted August 26, 2016 Tried changing the resistor? (Commonly called ballast or choke) 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 26, 2016 Share Posted August 26, 2016 Check the pollen filter if the motor is making a noise on all settings.could be blocked restricting air flow Quote Link to comment Share on other sites More sharing options...
rob61280 Posted August 26, 2016 Share Posted August 26, 2016 38 minutes ago, iantt said: Check the pollen filter if the motor is making a noise on all settings.could be blocked restricting air flow This did the trick for me, my fan was lethargic and the air con non-existant before I changed the filter. Now I have an icy cool breeze on setting #1 with 2-4 being too cold/windy for comfort. Quote Link to comment Share on other sites More sharing options...
