Knocking noise (leaf springs)
4 replies to this topic
#1 kovert
kovert
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Ford Model: escort van 2000 W reg
Posted 18 November 2009 - 07:21 PM
I have a 2000 W reg Mk 5 Escort van. Which has a knocking noise coming from the leaf springs It only happens or is worse when I go over a speed bump or ruff roads and seems to be worse when it is raining. I have taken it to the mechanics and he says they are fine . But is this a dangerous problem as i am rather worried as iam planning a road trip.
Thanks in advance
Also my clutch feels a bit springy Does it need adjusting .... TAR
Have something to contribute?
#2 marv_666
marv_666
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Ford Model: 1994 Escort estate 1.6.
Posted 19 November 2009 - 12:20 PM
Hiya,
is your van lowered?
Changes what it could be.
#3 lights
lights
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 25 November 2009 - 11:17 AM
Mine also does this knocking noise in the wet. I have covered 10,000 miles since it started. I've found when I have a small weight in the back it doesn't knock/bang.
I'm also after an answer to the problem
#4 InstructorPiggy
InstructorPiggy
  • New Member
  • 981 posts
  • Ford Model: Fiesta Mk7 TDCI ZS
Posted 25 November 2009 - 01:32 PM
If you got your back end empty, could be that as you go over the hump/bump, the back end bounces up and the leaf spring just has a minor gap in its bushings/fixings, then as it bounce back down you get the noise.
If mechanic says ok, try another to double check.
Piggy :)
#5 kovert
kovert
    Newbie
  • New Member
  • Pip
  • 8 posts
Posted 23 December 2009 - 01:59 AM
Thanks for all your answers To sort it out i have placed rubber inbetween the springs to stop the knocking Then cable tie them ( dunno whether its very safe ) . But am gonna bite the bullet and buy some replacements...
Not what you're looking for?
