3000 traffic displaying "1hour"
1 reply to this topic
#1 oneyearwonder
oneyearwonder
    Newbie
  • Pip
  • 1 posts
  • Ford Model: 1998 escort van diesel
Posted 12 June 2008 - 10:06 PM
i have just fitted a replacement ford 3000 traffic head unit to my works van, the new one is a slightly different model with the volume knob, when i turn it on either with or withoug ignition on it displays "1hour" for a few seconds
i have put the code in which i assume is right as before it displayed "code"
does anyone know why it shows this 1 hour message?
thanks all
i should also add that the unit seems to be fully working after displaying this message, but still shows it very time i turn off and on again
ta
#2 ivor bigun
ivor bigun
  • 32 posts
  • Ford Model: Titanium x pack sport pack 2008
Posted 20 June 2008 - 05:55 AM
thanks all
ta
Hi the 1 hour is a feature
it is a sleep timer if you have the ignition OFF the 1 hour timer kicks in and after an hour it turns off the radio to save the battery as the key is not in you may have gone away and left the radio on
If your radio does NOT come on with the key I think you have a ignition wire problem to the radio hence it always shows 1 Hour
http://img458.images...ereoford8hx.jpg quadlock
that is the wiring diagram for the plugs or
http://www.siocommun...6000-wiring.jpg the early one
check you have a wire that the power goes on and off with the ignition
the ford radio you have needs TWO power wires 1 permantly on for the memory and clock and 1 hour timer That you have
it also need an ignition wire to turn the radion on with the key
it may be only the radio fuse in your fuse box
If you are short of an ignition controled feed try the cigerette lighter socket a lot of Ford have ign control feed on them then a link from there to the correct pin on radio would do.
