mikester Posted June 14, 2011 Share Posted June 14, 2011 Unfortunately yours the Bluetooth only, without USB, the port on that just for the updates... i had same before... aha, so would need to buy a new module, cables and fiddle with the software and in theory this will work? has anyone else upgraded from this module? Quote Link to comment Share on other sites More sharing options...
Mr.Shabz Posted June 15, 2011 Share Posted June 15, 2011 checked mine and it's the 8M5T-19G488-AM model, which unfortunately i believe wont do usb, so would need to buy the new module. ahwell, trip to the scrapyard this weekend to se what i can find. cheers for your help guys. Quote Link to comment Share on other sites More sharing options...
chrsmi Posted June 29, 2011 Share Posted June 29, 2011 If i swap over head unit, display and bluetooth module from a titanium into a style+ is this likely to work? Quote Link to comment Share on other sites More sharing options...
nico008 Posted June 29, 2011 Share Posted June 29, 2011 sorry - double post - see next message please @ chrsmi : sorry I don't know Quote Link to comment Share on other sites More sharing options...
nico008 Posted June 29, 2011 Share Posted June 29, 2011 Hi there. I have a Ford Fiesta without USB plug next to the Aux plug. Anyway, there is an usb plug near the glovebox. When I plug my USB stick in it, the screen says "usb initialization" or something. When it's done, I press "Aux" button several times but nothing happens. But my USB stick works fine with another Ford Fiesta, which has USB plug next to Aux plug. Do you think it could work with my Fiesta if I follow digidash's steps with replaced steps 13&14 ? Are the two parameters correct and sufficient? Big thanks in advance! Damn!!!!!! I just went to garage. Unluckily it fails when downloading the modified configuration to the car. Only 1 parameter has been changed successfully Then we tryed like 4 time changing the other parameter (bluetooth module I think) This does not help: nothing happens when I press Aux button several times. Any idea what I could do? Of course I have the 8M5T-19C112-xx module! Thanks a lot in advance Quote Link to comment Share on other sites More sharing options...
mikester Posted June 29, 2011 Share Posted June 29, 2011 I have a feeling this was always destined not to work... Quote Link to comment Share on other sites More sharing options...
nico008 Posted June 29, 2011 Share Posted June 29, 2011 Anyone has 8M5T-19C112-xx module but not working USB? Quote Link to comment Share on other sites More sharing options...
shortcolin Posted June 30, 2011 Share Posted June 30, 2011 Any idea what I could do? It's interesting you had this problem - I think the Ford software might be buggy! I had a similar problem in that the "CD Player fitted" setting got reset, so the USB worked but the thing refused to acknowledge it had a CD Player! They solved the problem by downloading the original factory configuration from Ford (somehow - not sure how this is done) and then re-enabling the two bluetooth parameters. Failing that, perhaps it's possible to download the factory configuration of a car of identical spec that had BT/USB fitted from the factory and put that configuration into yours - I'm not sure. I did manage to get mine working eventually, so don't despair! Colin Quote Link to comment Share on other sites More sharing options...
nico008 Posted June 30, 2011 Share Posted June 30, 2011 Great news I will try this when I get back from vacation (~25 august) See you! Quote Link to comment Share on other sites More sharing options...
SOrchard Posted October 4, 2011 Share Posted October 4, 2011 Morning All, I've just found this thread and forum and joined to ask whether I can also have the USB connection. I have the standard 6 button radio without bluetooth or USB, can I add USB or do I have to upgrade the radio to the one with the telephone keypad? I also looked behind the glovebox, but I can't see this module everyone is posting about, presumably I don't have it to start with, but what cables am I looking for that will connect it if I get one? Cheers, Simon Quote Link to comment Share on other sites More sharing options...
irononreverse Posted October 4, 2011 Share Posted October 4, 2011 It's underneath the glovebox, in the footwell. There are two clips holding a plastic panel in place. And if you do have a bluetooth module, it's mounted on it. Quote Link to comment Share on other sites More sharing options...
SOrchard Posted October 5, 2011 Share Posted October 5, 2011 Nope, no BT module. I think it's going to be easier and cheaper to go aftermarket. My local Ford dealer want around £600 to upgrade the radio unit, whilst that would be nice because it would look nice there are adapter plates out there. Has anyone seen one of the Connect2 fascia plates installed, do they look particularly grim, or is it liveable with? Decisions, double height radio or single! Quote Link to comment Share on other sites More sharing options...
james_60 Posted October 5, 2011 Share Posted October 5, 2011 Hi Just my idea but why dont you just download a configuration for a car that already has bluetooth and usb installed and working cant this be done. Jamie Quote Link to comment Share on other sites More sharing options...
Lez Posted October 5, 2011 Share Posted October 5, 2011 If you have a bluetooth module, why just use the bluetooth steaming? I installed a high end module and usb, port, lead, but i use my Samsung galaxy s with bluetooth hands free, and steam music... Quote Link to comment Share on other sites More sharing options...
chrsmi Posted October 5, 2011 Share Posted October 5, 2011 I had a Parrot fitted for less than £200. All the same stuff. MKi9100. It's brilliant. Quote Link to comment Share on other sites More sharing options...
Lenny Posted October 5, 2011 Share Posted October 5, 2011 +1 on that Guys the Parrot MKi9100 is the best kit on the market in terms of usability, compatibility and reliability please note, if purchasing this kit or any parrot kit, you will also need to purchase an ISO cable to link the system to your stereo system, saves cutting any cables in your car, all you need to connect is the 12v power supply. parrot are a French company owned by Nokia another name you can trust another useless piece of off-topic information Quote Link to comment Share on other sites More sharing options...
SOrchard Posted October 6, 2011 Share Posted October 6, 2011 I had a Parrot fitted for less than £200. All the same stuff. MKi9100. It's brilliant. Did you have the UNIKA module fitted as well? Though having looked at it it seems to complicate things slightly, but does away with the Parrot remote? How ameanable were the fitters to putting the bits where you want them? I want the parrot screen in the little cubby behind the gear lever and the USB/iPod connection cables to come out in the "secret" hole. Quote Link to comment Share on other sites More sharing options...
SOrchard Posted October 6, 2011 Share Posted October 6, 2011 +1 on that Guys the Parrot MKi9100 is the best kit on the market in terms of usability, compatibility and reliability please note, if purchasing this kit or any parrot kit, you will also need to purchase an ISO cable to link the system to your stereo system, saves cutting any cables in your car, all you need to connect is the 12v power supply. parrot are a French company owned by Nokia another name you can trust another useless piece of off-topic information How do you connect the 12v supply? I think I might get it fitted, but then I'd fret that while the hidden stuff is done properly they might fit the visible bits where they want and not where I want. Quote Link to comment Share on other sites More sharing options...
irononreverse Posted October 6, 2011 Share Posted October 6, 2011 If you have a Bluetooth module, why just use the Bluetooth steaming? I installed a high end module and usb, port, lead, but i use my Samsung galaxy s with Bluetooth hands free, and steam music... Did you have the basic module to begin with? If so, did the bluetooth streaming work straight away or did it require a software update? Quote Link to comment Share on other sites More sharing options...
Lez Posted October 6, 2011 Share Posted October 6, 2011 Did you have the basic module to begin with? If so, did the bluetooth streaming work straight away or did it require a software update? I had changed my module to the higher one, but if you close to Bristol we can have a look on yours... Quote Link to comment Share on other sites More sharing options...
irononreverse Posted October 7, 2011 Share Posted October 7, 2011 I had changed my module to the higher one, but if you close to Bristol we can have a look on yours... I have the basic module, so if I were to upgrade I'd need the USB port, cables and fascia. Do you work at a dealership? Bristol's not too far from me. Quote Link to comment Share on other sites More sharing options...
Lez Posted October 7, 2011 Share Posted October 7, 2011 I have the basic module, so if I were to upgrade I'd need the USB port, cables and fascia. Do you work at a dealership? Bristol's not too far from me. No i`m not work in the dealership... for using the USB you will need the higher module too, but i think for the bluetooth steaming may be not, we can have a look with the IDS... Quote Link to comment Share on other sites More sharing options...
SOrchard Posted October 11, 2011 Share Posted October 11, 2011 +1 on that Guys the Parrot MKi9100 is the best kit on the market in terms of usability, compatibility and reliability please note, if purchasing this kit or any parrot kit, you will also need to purchase an ISO cable to link the system to your stereo system, saves cutting any cables in your car, all you need to connect is the 12v power supply. parrot are a French company owned by Nokia another name you can trust another useless piece of off-topic information Hi Lenny, I've got a Parrot MKi9200 waiting to go in, with an Autoleads SOT connector. Having played with the leads and connectors on the kitchen table I think I can see how it works, and it doesn't seem to need to be wired into the 12v supply, the plugs do it all. I hope... Anyway, the question I have is, whith your setup, do you get telephone muting on the radio with the Parrot kit, and which mute connection did you use, I have a choice of three, white, yellow or blue I think they are, but they don't seem to correspond with anything in the SOT lead. Slightly worried I've bought the wrong adapter, maybe I should have got an official Parrot one. Cheers, Simon. Quote Link to comment Share on other sites More sharing options...
odyssey Posted November 4, 2011 Share Posted November 4, 2011 I'm a little confused (I don't have a car with anything, but I'm going to try to retrofit it) Some talk about a USB-port at the glovebox. Where is this located exactly (pictures?), and what is it connected to? I was under the impression that the USB-port next to the 3,5mm line-in AUX is connected to this: The bluetooth unit I've got, is not the one with supposed "USB connectivity", so maybe it's just lacking a port for the other one? If anyone is selling the other model (or willing to swap with mine), I might be interested :) Quote Link to comment Share on other sites More sharing options...
iNath Posted November 5, 2011 Share Posted November 5, 2011 I'm a little confused (I don't have a car with anything, but I'm going to try to retrofit it) Some talk about a USB-port at the glovebox. Where is this located exactly (pictures?), and what is it connected to? I was under the impression that the USB-port next to the 3,5mm line-in AUX is connected to this: The Bluetooth unit I've got, is not the one with supposed "USB connectivity", so maybe it's just lacking a port for the other one? If anyone is selling the other model (or willing to swap with mine), I might be interested :) The USB port is the smaller of the 2 on that module - mine looks identical to that and has USB. Quote Link to comment Share on other sites More sharing options...
