* * * * * 2 votes
Adding USB to a MK7 with Bluetooth
308 replies to this topic
#211 mikester
mikester
    Drive it like a Granny
  • 656 posts
Posted 01 June 2011 - 06:12 PM
No - we need Adam!
he not at the dealership now. bit of a big ask to go to your old work place and use their stuff lol
i need to look at buying all this stuff so can make a start.
can you attach two of those ford cables (pictured previously-in grey) together to make it longer? reason being i want connect my iPhone via the armrest and not the USB port down by the gearstick. As a result i'll need to do some routing round the centre console up the back of the armrest.. answers on a postcard please :)
#212 nico008
nico008
    Newbie
  • Pip
  • 8 posts
  • Name: Nicolas
  • Ford Model: Fiesta
Posted 11 June 2011 - 01:59 PM
Hi there.
I have a Ford Fiesta without USB plug next to the Aux plug.
Anyway, there is an usb plug near the glovebox.
When I plug my USB stick in it, the screen says "usb initialization" or something. When it's done, I press "Aux" button several times but nothing happens.
But my USB stick works fine with another Ford Fiesta, which has USB plug next to Aux plug.
Do you think it could work with my Fiesta if I follow digidash's steps with replaced steps 13&14 ? Are the two parameters correct and sufficient?
Big thanks in advance!
#213 shortcolin
shortcolin
    Newbie
  • Pip
  • 8 posts
Posted 12 June 2011 - 06:34 PM
This sounds just like the problem I had when the garage had only set one parameter. Pressing 'voice'/'external device'/'usb' says "NOT POSSIBLE" also.
Enabling the other one got it working.
Colin
#214 nico008
nico008
    Newbie
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 12 June 2011 - 07:49 PM
Good news, I will ask my garage to do this next week or something, I will let you know.
Off topic : are there other things that are nice to customize in car configuration parameters?
Nice forum by the way :-)
Have a nice day
#215 lamby11
lamby11
  • 40 posts
  • Ford Model: mk7 zetec s
Posted 13 June 2011 - 01:29 PM
can some one post up a shopping list of whats needed im so confused as to which module i need and what wires
#216 lamby11
lamby11
  • 40 posts
Posted 13 June 2011 - 01:32 PM
oh yea with part numbers if possible
#217 nico008
nico008
    Newbie
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 13 June 2011 - 08:21 PM
I think the shopping list you are looking for is here : (Lez is talking about the module with USB)
yes i did...
and here again...
Part number : 8M5T-19C112-AN for UK English
Thanks for that but I was referring to the cable that connects to the port on the module and goes to the USB port by the handbrake, Is there an official product code for this?
edit; looks like it's these two cables that fit together to form one longer cable, no wonder the previous guy was complaining about the cbale being too short.
2 below connect together to form 1 cable.
Cable from the USB socket on the Bluetooth Voice Control with USB Module, which connects to the USB cable from the IPOD Holder -
FINIS: 1520708
Cable from the USB socket on the Ipod Holder -
FINIS: 1520710 8M5T-14D202-CB IP Cable, From: 25-02-2008 RHD, BT/VC Phone Interface + USB Connect
So these two cables, the USB faceplate and an update from Ford are allt hat's required? (besides the module)
Oh, also this:
SB Socket on the Ipod Holder -
FINIS: 1497339
Anyway, in my case I do not need to order USB cables since I already have some.
#218 Mr.Shabz
Mr.Shabz
    Newbie
  • Pip
  • 3 posts
  • Ford Model: Fiesta Zetec
Posted 13 June 2011 - 08:52 PM
Is it a case of making your own hole for the usb next to the aux socket, or is there an actual 'face plate' for it?
Im really looking to add usb to my fiesta, i have bluetooth & voice control already, and there is a usb hole on the module itself, so would this just be a case of buying the cables & getting the software update? cheers for the above finis codes.
#219 irononreverse
irononreverse
  • 853 posts
  • Ford Model: Ford Fiesta Zetec Mk7
Posted 14 June 2011 - 02:08 AM
Yes there is an official USB+aux faceplate.
As for the module, you'll need to check the code on it to ensure it's capable of Bluetooth audio. Both basic and high spec modules have the USB port.
#220 Mr.Shabz
Mr.Shabz
    Newbie
  • Pip
  • 3 posts
Posted 14 June 2011 - 08:53 AM
cheers, will have a gander for the faceplate. does the module have to be the high spec one if im just after usb playback? ta.
#221 irononreverse
irononreverse
  • 853 posts
Posted 14 June 2011 - 10:39 AM
Yes it does, the basic module isnt capable.
#222 mikester
mikester
  • 656 posts
Posted 14 June 2011 - 01:19 PM
How do you know which module you have?
#223 nico008
nico008
    Newbie
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 14 June 2011 - 02:32 PM
Check the part number on the sticker (see picture in post #217).
That module is under the glovebox. You have to remove 2 screw (1st pull the center of the screw if possible).
I just checked what part I have, it is 8M5T-19C112-xx :-) :-)
When garage change my car configuration I will let you know if USB works (I hope so!)
#224 mikester
mikester
  • 656 posts
Posted 14 June 2011 - 06:56 PM
So what does this mean for me? (see below)
#225 Lez
Lez
  • 276 posts
  • Name: Laszlo
  • Ford Model: Fiesta 1.4 TDCi
  • Year: 2009
Posted 14 June 2011 - 07:21 PM
Unfortunately yours the Bluetooth only, without USB, the port on that just for the updates... i had same before...
