* * * * * 2 votes
Adding USB to a MK7 with Bluetooth
308 replies to this topic
#226 mikester
mikester
    Drive it like a Granny
  • True Ford Enthusiast
  • 661 posts
Posted 14 June 2011 - 08:09 PM
Unfortunately yours the Bluetooth only, without USB, the port on that just for the updates... i had same before...
aha, so would need to buy a new module, cables and fiddle with the software and in theory this will work? has anyone else upgraded from this module?
Have something to contribute?
#227 Mr.Shabz
Mr.Shabz
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: Fiesta Zetec
Posted 15 June 2011 - 08:46 AM
checked mine and it's the 8M5T-19G488-AM model, which unfortunately i believe wont do usb, so would need to buy the new module. ahwell, trip to the scrapyard this weekend to se what i can find. cheers for your help guys.
#228 chrsmi
chrsmi
  • Budding Enthusiast
  • 54 posts
  • Name: christopher
  • Ford Model: Fiesta 1.25 Style+
  • Year: 2009
Posted 29 June 2011 - 10:00 AM
If i swap over head unit, display and bluetooth module from a titanium into a style+ is this likely to work?
#229 nico008
nico008
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 29 June 2011 - 10:20 AM
sorry - double post - see next message please
@ chrsmi : sorry I don't know
#230 nico008
nico008
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 29 June 2011 - 10:22 AM
Hi there.
I have a Ford Fiesta without USB plug next to the Aux plug.
Anyway, there is an usb plug near the glovebox.
When I plug my USB stick in it, the screen says "usb initialization" or something. When it's done, I press "Aux" button several times but nothing happens.
But my USB stick works fine with another Ford Fiesta, which has USB plug next to Aux plug.
Do you think it could work with my Fiesta if I follow digidash's steps with replaced steps 13&14 ? Are the two parameters correct and sufficient?
Big thanks in advance!
Damn!!!!!!
I just went to garage.
Unluckily it fails when downloading the modified configuration to the car.
Only 1 parameter has been changed successfully
Then we tryed like 4 time changing the other parameter (Bluetooth module I think)
This does not help: nothing happens when I press Aux button several times.
Any idea what I could do?
Of course I have the 8M5T-19C112-xx module!
Thanks a lot in advance
#231 mikester
mikester
  • 661 posts
Posted 29 June 2011 - 12:47 PM
I have a feeling this was always destined not to work...
#232 nico008
nico008
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 29 June 2011 - 03:06 PM
Anyone has 8M5T-19C112-xx module but not working USB?
#233 shortcolin
shortcolin
    Newbie
  • New Member
  • Pip
  • 8 posts
Posted 30 June 2011 - 02:44 PM
It's interesting you had this problem - I think the Ford software might be buggy! I had a similar problem in that the "CD Player fitted" setting got reset, so the USB worked but the thing refused to acknowledge it had a CD Player! They solved the problem by downloading the original factory configuration from Ford (somehow - not sure how this is done) and then re-enabling the two bluetooth parameters.
Failing that, perhaps it's possible to download the factory configuration of a car of identical spec that had BT/USB fitted from the factory and put that configuration into yours - I'm not sure.
I did manage to get mine working eventually, so don't despair!
Colin
#234 nico008
nico008
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Nicolas
Posted 30 June 2011 - 09:10 PM
Great news I will try this when I get back from vacation (~25 august)
See you!
#235 SOrchard
SOrchard
  • New Member
  • 36 posts
  • Name: Simon
  • Ford Model: MK7 Fiesta Titanium 1.6(120)
Posted 04 October 2011 - 07:59 AM
Morning All,
I've just found this thread and forum and joined to ask whether I can also have the USB connection. I have the standard 6 button radio without bluetooth or USB, can I add USB or do I have to upgrade the radio to the one with the telephone keypad?
I also looked behind the glovebox, but I can't see this module everyone is posting about, presumably I don't have it to start with, but what cables am I looking for that will connect it if I get one?
Cheers,
Simon
#236 irononreverse
irononreverse
  • 855 posts
  • Ford Model: Ford Fiesta Zetec Mk7
Posted 04 October 2011 - 12:53 PM
It's underneath the glovebox, in the footwell. There are two clips holding a plastic panel in place. And if you do have a bluetooth module, it's mounted on it.
#237 SOrchard
SOrchard
  • New Member
  • 36 posts
  • Name: Simon
Posted 05 October 2011 - 07:46 AM
Nope, no BT module. I think it's going to be easier and cheaper to go aftermarket. My local Ford dealer want around 600 to upgrade the radio unit, whilst that would be nice because it would look nice there are adapter plates out there. Has anyone seen one of the Connect2 fascia plates installed, do they look particularly grim, or is it liveable with?
Decisions, double height radio or single!
#238 james_60
james_60
  • 984 posts
  • Name: Jamie
  • Ford Model: 2013 Focus Titanium X 1.6TDCI 115BHP
  • Year: 2013
Posted 05 October 2011 - 07:49 AM
Hi
Just my idea but why dont you just download a configuration for a car that already has bluetooth and usb installed and working cant this be done.
Jamie
#239 Lez
Lez
  • New Member
  • 277 posts
  • Name: Laszlo
  • Ford Model: Fiesta 1.4 TDCi
  • Year: 2009
Posted 05 October 2011 - 07:37 PM
If you have a Bluetooth module, why just use the Bluetooth steaming?
I installed a high end module and usb, port, lead, but i use my Samsung galaxy s with Bluetooth hands free, and steam music...
#240 chrsmi
chrsmi
  • 54 posts
  • Name: christopher
  • Year: 2009
Posted 05 October 2011 - 10:32 PM
I had a Parrot fitted for less than 200. All the same stuff. MKi9100. It's brilliant.
Not what you're looking for?
