Bobx1x Posted November 19, 2009 Share Posted November 19, 2009 I own a 2006 130 tdci 67,000mls i have had it since new. It has been serviced on time and uptill now no problems have occured. However it now is starting to hold on to the engine speed when changing up or down the gearbox it holds at about the 2000rpm mark and on occasions will accelerate slightly when attemting to use engine breaking. I have cleaned the Egr and Manifold, as advised by mintalkin but still this problem persists. What signs and symtoms do Knackerd injectors have on the engine. and are these likely to cause this problem, if so , does anybody know of a supplier other than ford. Thanks in aticipation of your help. Dave (bobx1x) Quote Link to comment Share on other sites More sharing options...
peanuts Posted November 19, 2009 Share Posted November 19, 2009 Know ford want £200+vat per injector then need coding £80+ you could try pfjones of stretford 01618724755 £126+vat for recon or £168+vat fitted & coded good luck Quote Link to comment Share on other sites More sharing options...
Blackwhite Posted November 20, 2009 Share Posted November 20, 2009 It looks like Turbo problems not Injectors.Check intercooler pipe there is no leaks. Usualy if injectors are knackedr you will see "spring" led flashing. Quote Link to comment Share on other sites More sharing options...
