pringle1987 Posted September 12, 2016 Share Posted September 12, 2016 Hey all, had the final piece of Mountune hose delivered today as was out of stock! So when fitting the secondary induction hose it felt like it didn't quite fit properly, just the angle seems a little off on the elbow almost as if the longest end is a tad too long! Anyway got it on but my main concern is the breather hose! Even though the OE breather hose is fully clicked in it doesn't seem to sit properly and when you push it flush it returns to the pictured position... Is this normal/ok? Quote Link to comment Share on other sites More sharing options...
Joss max Posted September 12, 2016 Share Posted September 12, 2016 Hi in the bottom picture It certainly looks as if it should sit flush, rather than what the picture shows. Looking at the first picture, I would be tempted to slack off both the securing clamps either end of hose and rotate the hose at both ends to see if it brings the elbow up a bit so it lines up better and it sits fully on to the connector. You might want an extra pair of hands to help. Quote Link to comment Share on other sites More sharing options...
Willy Posted September 12, 2016 Share Posted September 12, 2016 Heres mine. There very similar. I put a bit of washing up liquid on the hoses when I fitted them. The engine cover is also a tight fit and sometimes needs a little foam removed where the pipe touches. 1 Quote Link to comment Share on other sites More sharing options...
T1M FF Posted September 13, 2016 Share Posted September 13, 2016 I suffered the same sort of problem when fitting mine was also abit concerned towards the end I undone the hose clips and shuffled the hose until it clipped in flush, seems ok now but do find myself checking it - 1 Quote Link to comment Share on other sites More sharing options...
WillKinsella Posted November 20, 2016 Share Posted November 20, 2016 Hi mate, I was looking under the bonnet of mine before and mine is all standard and mine sits like that. I haven't changed any hoses or anything and it sits like yours does. Wouldn't worry to much. Quote Link to comment Share on other sites More sharing options...
