Elpanda82 Posted September 13, 2016 Share Posted September 13, 2016 Hi all My 2012 Zetec S has developed a knocking from the steering wheel. Whenever I move the wheel from one side to another you can here the knock. Also while driving every time I hit a bump there's the knock and I can feel it through the steering wheel. Any one have any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted September 13, 2016 Share Posted September 13, 2016 steering column shaft probably needs greasing, was quite common on older ones, still the same shaft so assume it could be the same issue Quote Link to comment Share on other sites More sharing options...
Elpanda82 Posted September 13, 2016 Author Share Posted September 13, 2016 How do I fix it? Do I need to take the whole shaft out? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 13, 2016 Share Posted September 13, 2016 well , without feeling it, im assuming this could be the issue, i may be wrong, as for this issue it takes all of 5 mins to grease shaft. you ùndo the lower pinchbolt at bottom of column, and slide the shaft off rack pinion, carefull making sure steering wheel doesnt move slide shaft down exposing the splines, give splines a good grease then slide lowershaft up and down a few times to work grease in. refit shaft back in rack pinion , refit bolt and tighten. 1 Quote Link to comment Share on other sites More sharing options...
S7REE7Y Posted September 13, 2016 Share Posted September 13, 2016 I have similar problem with mine, 2010 1.4 tdci van, but mine squeaks when turning right? And only turning right could this possibly be a related issues? Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted September 13, 2016 Share Posted September 13, 2016 maybe, but normally it feels like a knocking Quote Link to comment Share on other sites More sharing options...
1.6 tdci zetec s Posted September 14, 2016 Share Posted September 14, 2016 11 hours ago, S7REE7Y said: I have similar problem with mine, 2010 1.4 tdci van, but mine squeaks when turning right? And only turning right could this possibly be a related issues? Thanks Ford spray the grease down the shafts. Don't use wd40. Quote Link to comment Share on other sites More sharing options...
Elpanda82 Posted September 14, 2016 Author Share Posted September 14, 2016 Cheers ianTT I'll give that a go 4 hours ago, 1.6 tdci zetec s said: Ford spray the grease down the shafts. Don't use wd40. What about wd40 spray grease?? Quote Link to comment Share on other sites More sharing options...
1.6 tdci zetec s Posted September 17, 2016 Share Posted September 17, 2016 I would not. Look into the type of spray grease ford use for this issue. I'll also look intoit as well, when I do find out what it's called I'll post it on here for you. Quote Link to comment Share on other sites More sharing options...
Elpanda82 Posted September 17, 2016 Author Share Posted September 17, 2016 Managed to fix mine today. Only took 30mins if that. Removed the whole shaft packed it with proper grease, then reinstalled. All seems to be working fine. Decided against the wd40 didn't seem thick enough. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 17, 2016 Share Posted September 17, 2016 thats good to hear, so your knocking noise has gone now? Quote Link to comment Share on other sites More sharing options...
Elpanda82 Posted September 18, 2016 Author Share Posted September 18, 2016 Yep no knocking noise. I did notice the top bolt wasn't as tight so could have just been that, but I greased it up just to be on the safe side. I'm a at these things but really was easy fix. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 18, 2016 Share Posted September 18, 2016 another happy forum member! ☺ Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted September 18, 2016 Share Posted September 18, 2016 Sounds just like what I had on our Fiesta, was advised to unbolt everything too and re-grease, decided not to do that got some old blankets and covered the carpet & pedals, then blasted the hell out of the two joints with spray grease whilst steering left & right, noise went away within minutes, wiped off excess grease and job done. Quote Link to comment Share on other sites More sharing options...
Andycclarke Posted December 11, 2019 Share Posted December 11, 2019 Hi I have a 2010 mk7 fiesta and the steering is not recentering I have changed a lot of parts including the rack and is exactly the same could this be a failing steering coloumn I don't want to replace it if it's not goi g to be the issue so can a bad coloumn cause it to not recentre what causes it to pull to the right thanks Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted December 12, 2019 Share Posted December 12, 2019 12 hours ago, Andycclarke said: Hi I have a 2010 mk7 fiesta and the steering is not recentering I have changed a lot of parts including the rack I take after changing the parts, you've gone and had the car fully checked & tracked at a decent tyre garage who knows what they are doing ? Quote Link to comment Share on other sites More sharing options...
