spooks01 Posted June 14, 2008 Share Posted June 14, 2008 HI ALL, need a little help. every time i go to start my car it wont start, i turn the key to position 2 and the needles on the dials fly all around the place. i go to start the carin position 3 and all i get from the engine is a ticking sound, for the last several mornings i hav had to bump start or use jump leads . is it my battery? my alternator? fuel pump ? Quote Link to comment Share on other sites More sharing options...
hotashel Posted June 15, 2008 Share Posted June 15, 2008 Hi, Could by batterey, allternator or starter motor. Try charging your battery, you can also get it tested to see if its still ok. H Quote Link to comment Share on other sites More sharing options...
michelle2008 Posted August 8, 2008 Share Posted August 8, 2008 Hi Mine has been making the same constant ticking sound whislt trying to start the engine and it just wont start, did you find out what the problem was with yours ? Thanks Michelle Quote Link to comment Share on other sites More sharing options...
